98 V70 FWD Clutch/Transmission
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Hi. I have removed clutch and removed the 10 bolts for the flywheel. Can't seem to figure out how to remove flywheel. See picture where I am at. First time doing this. Any trick to getting flywheel off? Please advise. Thanks
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Pry it off? It's only holding on by the rust...
85 GLH, 367 whp
00 Insight, 72 mpg
cuhfs
Post by cuhfs »
Thank you. Problem resolved. Pried it off. It was on real good. Used a tool to persuade it to come off.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Has thanked: 1611 times
Been thanked: 4072 times
How many hours to move that transmission off? Curious
cuhfs
Post by cuhfs »
Elephant of a job! Hard to say exactly how long to get to this point because I took small bites at a time going slow. My guess is 8 - 10 hours. so far
Here is how I broke the task down to bite sized pieces over two weeks done as follows. So far this has gone very easy. Not busted nor rusted bolts or stripped anything. Maybe because I have previously R&R steering rack and axles not that long ago...
SO far no regrets!
Basic steps were
Day 1
1.)Jacked and secured the car up pretty high. Supported engine from above.
Removed external slave Cyl.
Day 2
2.) Pulled Axles
Day 3
3.) Dropped Starter and Sub-frame
Day 4
4.) Detached Transmission
Day 5
5.) Removed Clutch and Flywheel.
Waiting for parts now then will reinstall new ones.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
