shutter during acceleration
tom4342
Year and Model: 1998 v70 awd
Re: shutter during acceleration
Post by tom4342 »
I did bring up the random intermittent code
Tom Hood
tom4342
Post by tom4342 »
Never have changed the fuel filter will do that in the morning
Tom Hood
tom4342
Post by tom4342 »
Fuel filter was a bitch changing but down found oil and trash in the cap cleaning that up
Tom Hood
tom4342
Post by tom4342 »
Distributor seal leaking into cap told it needs to be replaced how involved is that?
Tom Hood
Has thanked: 1501 times
Been thanked: 3812 times
Not too bad, you can pry out the old seal by puncturing it with a screw. There are some threads (!) on this in the VRD
woodsytf
Year and Model: '95 855 n/a; 275k mi
Post by woodsytf »
i owned a 2000 XCawdV70 that shuddered during middle-to-heavy acceleration.
i was chasing around for the cause for more than a year. throttle body, nope; plugs or coil packs, nope; fuel filter or pump pressure, nope...
it turned out to be a damaged tire steel-belt and a warped/damaged rim. one of my tires rode just fine in town or on the highway with no significant wobble or 'unbalanced' tire feel to it but when i had them balanced at a different shop they spun it up to wicked rpm's like 100 mph and it simply would not balance. (i'm guessing the Firestone at the end of my road only spun up to 56-60 or so) anyhow, when the tire technician guy removed the tire from the rim to inspect it also found that the rim had a subtle warp/damage to the inner lip. these two things combined to produce my weird acceleration wobble. after i replaced the tire and found a round salvage rim the shudder disappeared.
-woodsy
1995 855 275k miles
tom4342
Post by tom4342 »
When i first bought it in 2011 it did that over 65 got a tire rotation and balance and was good to go however she put 2 used tires on it so I am wondering if they are bad.Will check for codes when i get ti back.
Tom Hood
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Is it road speed dependant or engine rev dependant? Does each gear produce the same hesitation?
