Irregular front tire wear
Crbzk
Year and Model: s70, 2000
Post by Crbzk »
I checked out a family members car the other day to change the rotors and brake pads. Once I took the wheel off I was harshly surprised by metal wire sticking out on the inside of both front tires due to uneven wear. I'm not sure where the problem lies here, either suspension or alignment?
If anyone had any pointers that'd be great.
-Thanks in advance
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
First thing I would check is the control arms. You would see this kind of wear if the ball joint (s) are worn.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Year, make, and model? Were the tires rotate regularly?
85 GLH, 367 whp
00 Insight, 72 mpg
Crbzk
Post by Crbzk »
tryingbe wrote:Year, make, and model? Were the tires rotate regularly?
2000 Volvo S70 GLT To my knowledge the tires are actually 'new' for the most part
Crbzk
Post by Crbzk »
850 LPT wrote:First thing I would check is the control arms. You would see this kind of wear if the ball joint (s) are worn.
When I check the car out again I take a better look. Bad ball joints can be spotted by trying the push the raised tire from the top and bottom to see if there is any wiggle room, correct?
dosbricks
Been thanked: 4 times
Post by dosbricks »
Correct.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
It depends on how bad it's worn.
Pretty bad worn out control arm ball joint can have a wiggle to 9 & 3 o'clock as well,even if that positions are for examining tie rods condition.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1611 times
Been thanked: 4075 times
It's probably bad alignment due to worn out suspension. Ball joints( which means lower control arms on these cars) and both inner and outer tie rod ends are all suspect
