Hi there, first time posting I do believe. Bought the car last November or so and still working my way through bring it back to stage 0. Sadly it was pretty poorly taken care of.
A problem I've had since owning it is that I can't communicate with the obd2 port. I've tried autozone, someone with a serial port and another time I think. We could read other modules like abs and the tcm but not the ecu. The cig lighter works so that's not the issue
Any ideas what it could be?
'96 850R won't communicate with ECU
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Does anything happen at all when a scanner is plugged in? If I remember correctly there is a connector under the center console where some if not all of the wiring for the OBDII port runs through. If you're not getting anything at all out of that port it may be disconnected under the center console.
I had I had someone look at my car with what must have been some Volvo software. It had boxes for any computer he wanted to loom at like abs, trans or what have you, but the ecu was grayed out and couldn't click on it. So I'm assuming the obd2 port works, but I'll have a look at it just in case.
- misha
- Has thanked: 152 times
- Been thanked: 402 times
It have Motronic 4.3 engine management,so...if ecu examination was tryed with Vol-fcr....it will not work.
Try with a home made flash code reader since 4.3 is still producing flash codes.
It could be also that communication line was cut on purpose by previous owner.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 293 times
- Been thanked: 765 times
Yes, wire switch and LED is the "homemade reader" that misha is talking about. If that can't talk to the ECU through the OBD port, then nothing can.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- misha
I would check "k-line" before doing anything.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha what is "k-line" ???
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- misha
Communication line.
If it's broken somewhere in the system,from ecu to obdII port,ecu will not communicate with scanner.
European 850 from late '96 & '97 have chipped keys and immobiliser.That "k"line goes through immobiliser.
On U.s market cars,as far as i remember corectly,"k-line" avoids immobiliser and goes directly from ecu to obdII port.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
