Wheel rubbing '96 850R
WickyWah
Year and Model: 93 850 GLT, 96 850R
Post by WickyWah »
Okay, guys. I've spent the day trying to change my CV axles, struts, and end links. The CV axle was completely seized in the hub, so we had to bang it out with a hammer. The first end link we put on broke at the bolt, so we could only get one side done. When we got the whole thing assembled again and took a test drive I'm getting really bad wheel rubbing in the well. It happens when I turn to the right (we worked on the passenger side).Thinking we may have trashed the bearing when trying to get the axle out. Anyone have any thoughts?
Has thanked: 1609 times
Been thanked: 4065 times
It is hard to see how a trashed bearing alters steering geometry
More likely a broken upper strut bearing, ball joint, or tie rod end ( inner or outer)
