Came across a cluster and I have a Q
So this cluster on the serials have the same exact part numbers that my 01 cluster has. Except this is a blue dials cluster with the LED light strip on top. Even the MY stamp is same So, will this work in my 01 as a plug in play?
JRL
- Year and Model: Several
- Been thanked: 16 times
No
This is a 2004 R dash (DIM)
It may work but you won't have it light up at night
These are not backlit, they're front lit from above and your 01 has no wires going up there at all
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Sometimes an owner will mod the cluster to add the blue dials. If I remember well, the 2248 and the 620T numbers are the most important to be matched (the digits will vary depending on the car)
- dim.jpg (91.83 KiB) Viewed 1525 times
Any idea if it the dials will mark...like fuel and mph with temp? I am not worried about the above LEDs. Like I said all numbers match what I have in my 01. I need to swap my 01 out since it crapped, ID figure if this works I can upgrade.
- oragex
If all numbers match it should work although I thought only 2002 and 2003 are interchangeable, maybe the 2001 is interchangeable as well. Given the blue dials were only on 2004+ R models, clearly the owner has put the blue dials which is a nice mod.
I would say, don't discard the 2001 cluster and try to have it fixed later on. I had mine done by a tv shop for less than $100. The 2001-2003 all fail so it's good to have a spare one not to mention it will have the original mileage.
