Good evening everyone . I had recently an issue with my 99 C70 2.4 T , the issue in question is when I'm on the freeway my engine won't pass 4000 rpm even if I'm doing over a 100 mph . My CEL is on but for a vapor issue from the gas cap . I heard that it could be a Catalytic converter , but I have no idea .
Any help or answer please ???
Engine won't pass 4000 rpm
Ethan Slatnia
- Year and Model: C70 2.4 T 1999
- Year and Model: Many Volvos
- Been thanked: 76 times
It could be a bad tach. Just revving in neutral will it go above 4000?
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
I had a problem on the high end, turned out to be plug wires. At the higher rpm's, they just broke down. Worked fine at lower power. Changed the wires, and fixed it.
Also, is it possible that you have a waste gate leak?
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
Ethan Slatnia
Thank you for all of you guys for the quick response.
Lee, even when.im at P the engine won't pass 4000rpm.
Pkc303, I'm sorry what do you mean by waste gate leak? Is it that serious ??!
- pkc303
Mine will not in Econ mode, but does in Sport mode. Do you have a switch to change modes?
I'm not familiar with the C70, so I may be way off here. I have 850R's
- misha
- Has thanked: 155 times
- Been thanked: 432 times
N/a cars will NOT rev past 5000 rpm in neutral,should be the same for turbo ones too.It's a safety feature because it's not good for the engine.
It certailnly must rev past 4000rpm at idle.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
A very good friend tells me a 1999 T5 M revs 3750 at 100 mph.
