Which odometer gear usually fails
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
My odometer stopped working recently and I'm looking at replacement gears. Which gear usually fails, main drive gear or pod gear?
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
The usual suspect is small gear but I always replace both of them. The large gears have been soft on all of them that I have replaced.
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
I used IPD kit for $19.95 in 2010 to restore the dash -- magical.
On Volvo 850, I will lift the top cover off completely next time, NOT just the driver's side as IPD suggests. Now loosened with unseen damaged clips and fasteners - it shakes and squeaks.
Here is more https://www.ipdusa.com/prodtype.asp?CAT ... rumbs=1053
JimBee
Post by JimBee »
xheart: did the IPD kit come with just the one gear? Or did you order the second one separately and change that too?
pkc303
Year and Model: 1995 T-5R Yellow
Been thanked: 3 times
Post by pkc303 »
I changed both in mine, and they both were broken. Ordered it from a guy in Hungary, made with detran plastic. It works like a champ. Good price. I think there is a thread on here with the information.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
Post by Ozark Lee »
My go to guy is Jeff Caplan at odometergears.com. They are a bit pricey at $25.00/gear but they are perfect and they will last forever. I do re-lamp everything while the cluster is out and I also remove the Service light.
xHeart
Post by xHeart »
JimBee wrote:xheart: did the IPD kit come with just the one gear? Or did you order the second one separately and change that too?
After much deliberation, I order the kit only -- one gear and the dash bulbs.
It is working with zero issues.
I would keep the Volvo original if there is no damage to larger gear. Look closely with a magnifier, i did, it looked crisp as new.
JimBee
Post by JimBee »
Helpful discussion, thanks all!
kaneelschep
Year and Model: '96 850 2liter t5
Post by kaneelschep »
Here in Holland a guy makes them out of brass and sells kits including the light bulbs. ETS is the name I think.
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
And it is possible to install the gear upside down- ask me how I know !!
