Which odometer gear usually fails
JimBee
- Has thanked: 25 times
- Been thanked: 42 times
My odometer stopped working recently and I'm looking at replacement gears. Which gear usually fails, main drive gear or pod gear?
- Year and Model: Many Volvos
- Been thanked: 75 times
The usual suspect is small gear but I always replace both of them. The large gears have been soft on all of them that I have replaced.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
I used IPD kit for $19.95 in 2010 to restore the dash -- magical.
On Volvo 850, I will lift the top cover off completely next time, NOT just the driver's side as IPD suggests. Now loosened with unseen damaged clips and fasteners - it shakes and squeaks.
Here is more https://www.ipdusa.com/prodtype.asp?CAT ... rumbs=1053
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
I changed both in mine, and they both were broken. Ordered it from a guy in Hungary, made with detran plastic. It works like a champ. Good price. I think there is a thread on here with the information.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
My go to guy is Jeff Caplan at odometergears.com. They are a bit pricey at $25.00/gear but they are perfect and they will last forever. I do re-lamp everything while the cluster is out and I also remove the Service light.
xHeart
After much deliberation, I order the kit only -- one gear and the dash bulbs.JimBee wrote:xheart: did the IPD kit come with just the one gear? Or did you order the second one separately and change that too?
It is working with zero issues.
I would keep the Volvo original if there is no damage to larger gear. Look closely with a magnifier, i did, it looked crisp as new.
kaneelschep
- Year and Model: '96 850 2liter t5
Here in Holland a guy makes them out of brass and sells kits including the light bulbs. ETS is the name I think.
