Low Idle How to Increase?
mnorris23
Year and Model: 2000 S70 2.4l GLT
Post by mnorris23 »
Hey everybody, I've read that you can increase the idle level somewhere on the car (2000 S70 GLT) and since I'm idling at a low RPM I was hoping I could get advice on how to increase it. Is there a knob or something that I can turn to increase my idle level?
Car I own: 2000 Volvo S70 GLT 130k Stock with OEM replaced parts.
Been thanked: 4065 times
Not adjustable, unlike your grandfathers Volvo.
Engine management is now a science
mnorris23
Post by mnorris23 »
abscate wrote:Not adjustable, unlike your grandfathers Volvo.
That sucks :/ sometimes gotta hate electronics.
the cars are more efficient and much more reliable than past. If your idle Speed isn't right, you probably have a vacuum leak of some kind.
mnorris23
Post by mnorris23 »
abscate wrote:the cars are more efficient and much more reliable than past. If your idle Speed isn't right, you probably have a vacuum leak of some kind.
well right now my ETM isn't programmed for my car (had to replace a failing one and am stuck with a incorrectly programmed ETM) which is causing low idle due to the throttle position to be incorrect. Could this damage my car having an incorrectly programmed ETM put in? I plan to replace it with a good one programmed correctly eventually.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
It will eventually kill the cat converter which is an expensive part of the exhaust system.
