"Reduced Engine Power" Limp Mode Topic is solved
VolvoBooster
Year and Model: 2004 Volvo S60 2.5T
Post by VolvoBooster »
Hello everyone.
I have perused these forums many a time. I am thankful for the advice, help and assistance that the users of the forum have offered and shared. It was appropriate for me to go ahead and ask for help when the many topics I have read over, although relevant, have left me with an unsolved issue.
I have a 2004 Volvo S60 2.5T. Just reached 120K last week. I've been getting the message: "Reduced Engine Performance," along with the car going into limp mode. It does not go above about 10-40mph and won't accelerate reasonably. Clearing the codes with my OBDII scanner once I have the key in position II with the car off temporarily solves the issue. It allows me to run the car- perfectly with no issues, no rough idle, running just fine. It runs well until I turn the car off. when I turn it back on, the code returns along with the limp mode. It has not randomly gone into limp mode while driving, only when I start the car, without clearing the codes.
The codes I have are:
p2111- Throttle Actuator Control System - Stuck Open
(Throwing it twice previously)
There was an O2 Sensor Code, Lambda Sensor... something something, but I replaced the front O2 sensor and that code went away. This was a code I had a long time, before the car starting going into limp mode. I am thinking that this is likely unrelated- but I am not the super-expert... ...yet. :P
Other potentially relevant facts:
- The "vacuum pump clip" under the hood has broken off as well. I have to manually place it there frequently.
- I am just about due for an oil change, exceeding the date but just under the miles recommended.
- I read people having an issue with the pedal sensor. ... I'm not sure.
What I have done:
Cleaned the throttle body, thoroughly, then placed a new gasket on it and put it back.
- I recall, the throttle body plug didn't look too dirty anything.
Took the battery off the proper way for at least thirty minutes- even overnight.
Cleaned the MAF.
Checked the air filter.
Charged the battery at AutoZone.
Plugs were replaced about 5 months ago.
I have a VIDA on the way.
Thank you for taking the time to read. :)
Any idea?
Has thanked: 1498 times
Been thanked: 3810 times
It sure sounds like you need a new throttle body, but, fear not, after reading all the nastiness about the Magnetti Marelli ETB, you have the Bosch on your car which is about 500 USD, but no software to be matched, upgraded etc.
31216327
It would be worth getting one from a PnP for less than half that, though, They rarely go wrong.
nsjames
Year and Model: 04 XC70
Post by nsjames »
rockauto currently has the Bosch unit for $280.
it does have a wide range of interchange, so a used unit may be easy to come by.
VOLVO S60 2001-2009
VOLVO S80 2002-2006
VOLVO V70 2002-2007
VOLVO XC70 2003-2007
VOLVO XC90 2003-2006
volvobro
Year and Model: 2004 S80 2.5T AWD
Post by volvobro »
I had the exact same problem as you on my s80, and I was convinced my throttle body had failed (even though, as mentioned above, they rarely fail unless there's water damage).
My problem was due to the throttle body connector plug being loose/damaged. The connection between the throttle body and wiring harness was literally being held together with a zip tie... Lol.
Sometimes, cleaning it would make the symptoms go away, but it evidently needed replacing.
It was difficult finding a replacement, not to mention having to splice in the new connector plug, but the problem went away after that.
2004 S80 2.5T AWD - First car, first Volvo.
Follow my progress to stage 1 here.
VolvoBooster
Thanks everyone, I am really glad for such forums... ...You all are awesomeness. Okay,
abscate wrote:It sure sounds like you need a new throttle body, but, fear not, after reading all the nastiness about the Magnetti Marelli ETB, you have the Bosch on your car which is about 500 USD, but no software to be matched, upgraded etc.
31216327
That's so strange... per my vin number, a Volvo dealer says I need:
30711554
I had "8677866" in there, which is a foreign number, per Volvo's information.
This is the thing, I got the intake manifold along with the throttle body replaced about 10 months ago. This was because I wanted to get the most horse power out of it. The reason why I had to do this was because I decided to clean the throttle body and not put a new gasket back on- not a good idea ...just to after that I broke off one of the four bolts on the throttle body. I didn't have the knowledge I have now. Not putting a new gasket on made the car idle slightly more roughly and throw some codes. But the car ran generally fine. Instead of drilling or something similar, the mechanic I work with decided just to replace the intake manifold altogether along with throttle body from another car- could've been a V70. I'm not at all sure. Those issues went away after the replacement and the car has run fine since then. This previous issue is something that has been resolved- not be confused with any of the current issues talked about. I just explained the back story for reference.
Any-who,
I do have a used 30711554 I already ordered coming this week. Being I'm a student, I wanted to try a more economic solution. :)
Should I be looking at the 31216327 instead?'
I wonder if this 30711554 is simply an updated version, not the one that would've shipped stock when the car was manufactured. ...This I do not know.
Thanks gentlemen (and gentleladies).
VolvoBooster
@volvobro
When we are referring to:
volvobro wrote:The connection between the throttle body and wiring harness
are we talking about the connector that goes from the car to the throttle body? I think it's six pin, if I'm not mistaken. Whatever it is, it didn't look dirty, and I specifically looked at it, but I will try to get some CRC electric cleaner along with dielectric grease (If you all think that's a good idea!?) and clean the contacts. Who can tell dirt from the eye? I will attempt to clean it without fully taking apart everything, straight from the hood, I am thinking.
I'd go with the Volvo dealer part number based on VIN. I pulled mine from FCPEuro
volvobro
Post by volvobro »
Yes, that's the connector I'm referring to. Even if it's not dirty, it could still be the source of your problem, and it's way cheaper to replace it then to replace the entire throttle body.
Here's my thread for when I had the same problem:
https://www.matthewsvolvosite.com/forums ... hp?t=71156
nsjames
Post by nsjames »
dielectric grease is an insulator.
you can use it to seal up the connector by applying it to the rubber gasket, or the back where the wires enter, but do not apply it to the pins.
VolvoBooster
Thanks so much.
@volvobro: I'll be looking at that thread more closely.
So guys, while driving, I see that cruise control now does not work... How does this affect or change things?
