Moving along
- Has thanked: 2207 times
Check the vacuum pipework for the cruise control. The rubber parts fail.
Knock sensor try just a clean of the connector. Try the simple stuff first.
- dosbricks
- Been thanked: 4 times
I think there was a TSB for 1996 (maybe '97 also) because years ago I had an updated wiring harness installed when I got a knock sensor code. Last year when I had my engine out to do the RMS, I found this to be about the only place where it was possible to get wire connectors switched. Since you swapped engines, if you have an extra bundle of wire that attaches to a white bracket, you may have this extra harness. If so check for orientation of the wiring. Otherwise, disregard all of the above.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Check that the rod is connected to the gas pedal
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- Year and Model: Lots
- Been thanked: 128 times
I had loose bolts on both knock sensors (one was almost finger tight) which lead to codes on a 2001 XC70. Taking intake off was the only access.
- Been thanked: 4071 times
Don't over tighten them though, the spec is really low. If you crank on a 6 inch socket handle, you will overtorque
Even on the 1999 the cruise light only comes on during engagement, it doesn't even come on during lamp check in key Pos II.
Evan listed on this during his cruise tribulations
- 1731 Views
Last post by darrylrobert
- 837 Views
Last post by nsjames
- 1384 Views
Last post by erikv11
- 1733 Views
Last post by yagger
- 717 Views
Last post by Mr. Detail
