Replace Rear Wheel Bearings 1998 XC70
mantz.josiah
Year and Model: 1998 xc70
Post by mantz.josiah »
Has anyone done a wheel bearing replacement for your 98 volvo xc70? If so, could you please let me know the difficulty level of this repair? I'm finding differing opinions online and wanted some clarification from someone who's actually done the job already. Pictures or videos would be great. Thanks.
renns
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 6 times
Post by renns »
My '98 AWD rear wheel bearings are pressed into the hub casting, while as I understand it later models are mounted in a carrier that can be unbolted and replaced more easily. On mine, a press was needed to press the old bearing out, and push in the new one. Also, the retaining ring holding the bearing in place was rusted badly, and needed lots of heat with a torch to get it out of the groove. Without torch and hydraulic press, I'd never have been able to complete this job.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
mantz.josiah
i guess it won't be as easy as i had hoped. thanks for the insights though!
Has thanked: 2200 times
Been thanked: 1852 times
It is not easy as renns says. A press is needed. Best method is to find a rear hub assembly at a Pick and Pull type yard, but V70 AWD are not thick on the ground and you can't use a V70XC rear hub as they are different.
Been thanked: 4065 times
Anyone have a picture? Most rear wheel bearings I've come across call for a press, but I've knocked them out with a hammer and punch, and put them back in with a socket....
