OK
I did a trans oil flush yesterday using the top line to the rad method... nice and clean way to do it!! I then replaced the upper torque mount that was bad and VOILA!!!!! no more bumping of the transmission!!!!
2000 V70 bumping from second down to first
goldmandan
- Year and Model: 1999 S 70, 2000 V70
- Year and Model: Lots
- Been thanked: 128 times
BTW you can reset adaptations and do a fluid counter reset on a P80 5 speed Aisin but there is no drive cycle menu in Vida unless you have a P2 series. Primarily this is because the DIM doesn't have a triangle to advise optimal shifts.
If you have Vida you can verify this. It will take about 600 miles with city driving to adapt the TCM.
Good that you got a result without doing above. Just hope it sticks for you.
goldmandan
I have an autel maxisys pro that can reset the adaptations and reset fluid change counter. Good point I will do that this morning
Dan
Dan
- 25 Replies
- 6098 Views
Last post by goldmandan
- 13 Replies
- 2303 Views
- 1633 Views
Last post by j-dawg
- 1794 Views
Last post by FCPEURO
- 1086 Views
