99 v70 glt running rough
huzzsaba
Year and Model: 2004 volvo xc90 2.5t
Post by huzzsaba »
Suppose I clean the current etm and it improves the idle, how long do I typically have before it will eventually fail for good?
2004 Volvo xc90 2.5t
1998 Volvo s70 T5M
Has thanked: 1611 times
Been thanked: 4074 times
I think Im the record holder for the longest lived original 1999 ETM at 137k miles and 12 years.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
The wife's original ETM is still going strong on a '99 V70 with nearly 200K miles and coming up on 16 years on it.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
huzzsaba
Post by huzzsaba »
So does that mean there is hope in it improving with a cleaning considering it only 125 k miles on it?
1998 Volvo s70 T5M
Im in a solid second place... :-)
Be careful with cleaning so you don't get solvent into the electronic part of the ETM. And, if you open it up and it looks clean like mine, don't mess with it.
The part that goes bad isn't the throttle plate, its the sensor inside the ETB that is a mechanical wiper. I want to say I drove mine for a year or so, maybe 15000 miles before it finally went permanent limp mode and I had to deal with it.
huzzsaba
Post by huzzsaba »
2 questions:
So I'm taking things apart to get to the ETM and I find this part with the hose missing. Where is the hose that connects to this part in the second photo? Would this cause rough and fluctuating rpms at idle like I am experiencing?
Second question is in regards to the charge air pipe being in the way of removing the cooling fan. Do I need to take charge air pipe off to be able to remove the cooling fan? Seems like a nightmare to attempt loosening the charge air pipe clamp from Etm with the coolant fan in the way since.
1998 Volvo s70 T5M
Purge valve for evap emissions. Missing hose there will cause rough running.
Use under hood vacuum diagram to put that Right
huzzsaba
Post by huzzsaba »
UPDATE:
SO I got the new etm from Xemodex and put everything back including the hose hose that was disconnected. It started up fine but started sputtering every little while. No codes!
Basically it was idling smooth and then starts sputtering randomly. While drivingit it will drive smooth with power then there will be a series of sputters then it will smooth out again. at higher rpms it revs smooth but at lower rpms it starts sputtering. Not sure if I mentioned this before but the car was sitting for a good 6 months so I am suspecting that the fuel filter is clogged since it is intermittent at low rpms and smooth at high rpms and there is no CEL.
Any suggestions?
1998 Volvo s70 T5M
Has thanked: 2210 times
Been thanked: 1852 times
Is the fuel in the fuel tank the original from when it was sitting for 6 months? If it is you may want to drain it and put fresh in. Modern gas goes 'off' quickly. If the tank is low, then add fresh fuel to dilute the old and see if that helps. If he filter is of unknown vintage it is worth changing anyway.
Next to check would be fuel pressure. Pressure should be 42psi at the rail minimum.
Sounds like you are getting there!
A good long run may help also to blow out the weeds.
huzzsaba
Post by huzzsaba »
Thanks Scot850 for your reply.
When I got the car, there was very little fuel in it and the gas light was on. On the drive home I put in around 30 litres of 94 octane fuel from Petro canada in hopes that it would clean out some of the gunk from sitting. I drove it around 30 kms since putting the fuel so most of the fuel in there is newish.
I think I will put a new filter on and do a italian tune up on the highway lol.
I will post an update.
1998 Volvo s70 T5M
