98 V70 AWD turbo charger bypass valve
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
On my daughter 98 V70 AWD I noticed that there was little of no noticeable kick in the turbo charger. Was not throwing any codes, TCV ops checked good and the three turbo lines were only a year old. After some research I came across IPD vidieo on the bypass Valve or the diaphragm being torn. This car was showing all the symptoms of a torn diaphragm. After removing the intake turbo pipe and some hoses there were three 10mm bolts holding on the compressor bypass valve cover. After removing the cover the diaphragm and spring easily came out. Upon inspection of the diaphragm found no tears but chaffing causing holes letting air thru thereby providing little or no pounds of boost.
The IPD kit contained three springs, stock, slight upgrade then aggressive. I choose the middle spring. Install was straightforward. The step by step pictures and narrative included in the kit were outstanding.
The car has regained it's performance. It was a noticeable difference.
Has thanked: 311 times
Been thanked: 817 times
Great post, this problem is more common than people may realize. Almost all of the original CBV diaphragms have holes in them, every one I've checked so far.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I have a Volvo one that is in perfect shape if anyone needs one. I can take a picture and send it to you via email or txt too.
101
Year and Model: 98 V70GLT, 98 S70T5M
Post by 101 »
Mine had a small hole at 211K miles. This should probably should be added to a "Stage 0" workscope. It's inexpensive enough and easy to replace.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
Been thanked: 4065 times
On my 1999 T5, this was one of the worst replacements I've ever done on a car. I think it took me 4 hours to do those three M6 bolts with all sorts of convolution of 1/4 ratchets and wobbles. Access was very tight compounded by the metal coolant hose.
Performance afterwards put the local BMW challenger into rear mirror retreat. I used the blue spring
Bluevanacd2005
Year and Model: 1983 760
Post by Bluevanacd2005 »
Not trying to highjack the thread, but I see IPD also sells a block off plate. Has anyone installed it? Bad idea?
Spenser
I like curves on my women, not my cars
101
Post by 101 »
101 wrote:Mine had a small hole at 211K miles. This should probably be added to a "Stage 0" workscope. It's inexpensive enough and easy to replace.
abscate may be right. I need to qualify my response about this part being "easy to replace". It's easy to replace when the cylinder head is off the car. :D
I didn't try to access it with the engine fully assembled.
101
Ha! Multiple lashes for witholding information!!!
The worst part of this job was getting it back on in two hours, then seeing that the nice new turbo valve had popped out and fallen under the car while I had not noticed, so I had to remove it and do it again. The fact that it took another two hours the second time tells you how nasty it was.
Link to thread on 1999-on Compressor Blowoff Valve
https://www.matthewsvolvosite.com/forums ... =1&t=70733
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
There is also this for the Mitsubishi OEM crowd. This will be the direction I'll be heading. At this point my 850 will never be a racer. http://www.xsboostturbochargers.com/pro ... dge-srt-4/
On a 98 and earlier, the job is a pain but not nearly as bad as it was for abscate; I think there are different metal cooling lines back there? Anyway it takes an hour if you go carefully but it is not a killer.
