I'm guessing they mean bleeding the brakes.
We heavily grease our sliders and caliper pins on every car I've owned in the Northeast for 40 years
new brake discs?
- Has thanked: 1611 times
- Been thanked: 4072 times
qwertyjjj
- Year and Model: V70 2004
I looked up Akebono set of brakes i Canada and they cost $128.93 for the front set?oragex wrote:The quote is parts only? Is so, I'd forget them, it's very expensive and they will probably put cheap parts.
Never heard about oiling the discs. Perhaps they meant the caliper pins, which should not be greased on a Volvo.
You can buy the parts online. I am pleased with the Akebono pads, brembo disks are good, others may suggest other options.
qwertyjjj
How much should the total roughly be for a set of pads and discs front and back including labor?
Secondly, can I change only the front set and wait a few months to do the back. The garage said the last time that the front set were more worn.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Sure, just need to replace those who are worn. Usually they won't wear at the same rate (front and rear).
These are the front pads I installed last week, run for about $100 Cad after currency conversion. They grip well, and most importantly no more brake dust
I haven't look for discs, as for the labor time, personally with jacking the car in my garage, it would take me 30min. per corner if I work quickly. The trick is with releasing the caliper bleeders (in order to install new pads) which might be stuck, especially at the rear brakes.
http://www.ebay.com/itm/291662864747?_t ... EBIDX%3AIT
May worth taking a look on local advertising such as http://www.kijiji.ca, sometimes there are people who work at the dealer and sell original parts at discount prices.
qwertyjjj
I guess itès the discs or rotors that are expensive in this quote? Pads are okqwertyjjj wrote:I'll go grab a pic in a moment.
Garage has quoted me :
Set Front pads CAD$106
Set Front discs CAD$240
Oiling front discs CAD$10
Set back pads CAD$88
Set back discs CAD$211
oiling back discs CAD$10
Then it's $80 per hour labour
Yep labour would be on top so probably another $160 plus and then tax.
80 CAD per hour is really cheap? Is that right for labour charges?
- oragex
$70-$80 cad +tx is about average for a main city 'clean' garage (non dealer). There are lousy places that will charge $50-$60 but you will probably leave with a greasy driver seatabscate wrote:80 CAD per hour is really cheap? Is that right for labour charges?
Wow. My local indie here in NY is 100 per hour USD. I think Im driving to Canada next time I need work...
qwertyjjj
It's not the labour I'm worried about, it;s whether the rotors are too expensive?oragex wrote:$70-$80 cad +tx is about average for a main city 'clean' garage (non dealer). There are lousy places that will charge $50-$60 but you will probably leave with a greasy driver seatabscate wrote:80 CAD per hour is really cheap? Is that right for labour charges?(and then there's the Volvo tech that works by his home)
- oragex
I hope they quoted for original Volvo parts at that price. A Volvo disc sells for $100 cad here (you need to measure the ones on the car to check which exact size they are), this is just as example
https://www.eeuroparts.com/Parts/62092/ ... -31262707/
