'99 v70 Window stuck down -- can I put it back up?
Has thanked: 1609 times
Been thanked: 4064 times
Sounds like the motor. Looking at that diagram it looks to me like the motors are wired hot and are grounded through the door switch. You should have 12 volts at each switch, if you don't, there is an open in the wiring or motor
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
abscate wrote:Sounds like the motor. Looking at that diagram it looks to me like the motors are wired hot and are grounded through the door switch. You should have 12 volts at each switch, if you don't, there is an open in the wiring or motor
Flip that - Both legs are grounded at rest.
When a switch is actuated, the ground for
one side is lifted and 12 volts is applied.
Operate the switch the other direction
and the the same thing happens to the
opposite motor lead, reversing polarity.
juggles
Year and Model: 1999 V70
Has thanked: 2 times
Post by juggles »
Progress, sort of. I was able to short the driver's side enough to get the window to raise a couple inches. The motor is failing intermittently. Looks like if I can get it high enough, I'll be able to remove the glass. I got a replacement motor from a junkyard.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
juggles wrote:None of this seems to be working. I've ordered a new switch but I still think the problem may be elsewhere. In the meantime, is there any way to mechanically crank or pull the window back into place?
You can crank it back up mechanically but you need to remove the interior door panel to do so. We have several writeups and I think Robert has a video on how to remove the panel and what to expect as far as broken clips, mounts, and panel delamination that will rear its ugly head in the process.
Once the panel is removed, so long as the window is still on its tracks, you can peel back the sticker that covers the the manual override on the motor. As I recall it is a torx head and it is fairly large, like a T45 and it is centered on the gearcase next to the electric motor. It doesn't take a great deal of force but using a ratchet is the easiest way to do it. I was tempted to use a battery drill but I didn't want to risk shelling out the gearcase so I did mine with just a ratchet and was careful not to go too hard in the wrong direction.
BEJinFbk
Post by BEJinFbk »
I'm not sold that it's the motor. If it's working at all, it's probably OK.
Those things are pretty stout and it's extremely rare to see a failure.
Bad connections while hot wiring, low voltage or something going on
with the window regulator seem more likely to me. Just saying'...
I like the idea of operating it manually. If something mechanical is
hanging up, it should be pretty easy to tell. Hopefully you won't have
to take everything apart and it's a bad channel roller or a bad contact
in one of the connectors or something easier than a motor swap.
When you get to that point, if you still need a hand, it's
pretty easy to post pics here. Give us a look at it!
juggles
Post by juggles »
I've got the door apart, but I don't see anything that looks like a sticker covering the manual override on the gearcase. Here's a picture. Am I missing something?
Also, got a replacement switch this morning. The driver's side motor has worked a little in fits and starts, not enough to get the window all the way up. Smoke was coming off the motor earlier.
BEJinFbk
Post by BEJinFbk »
Bummer. All that I've got left is to unplug the motor connector
and inspect the contacts. Maybe try applying voltage directly.
But everything looks pretty clean there.
IIRC, to get the regulator out, you've got to get the window to the right
level to pull the track rollers. With a dead motor, that's gonna be fun...
Where was the smoke coming from?
Post by Ozark Lee »
I steered you a bit wrong on the location. The silver circular grommet just inboard of the motor is where the manual actuator is. There is a sticker over the hole but you can just punch through it.
juggles
Post by juggles »
Ozark Lee wrote:I steered you a bit wrong on the location. The silver circular grommet just inboard of the motor is where the manual actuator is. There is a sticker over the hole but you can just punch through it.
OK, punched through the sticker, removed the grommet also. Here's what I found. Is there a tool that fits in that semi-circular hole?
Post by Ozark Lee »
Hmm, mine had a torx socket in it. Try a screwdriver I guess.
