In your third post, "but there is normal pressure reading from the jump at relay terminals 30-87/2."waynegarbo wrote:If you mean 87/1, with 87/2, and 30 and start, No.
With a normal pressure reading, does vehicle start?
Let's see, vehicle has,'waynegarbo wrote:No....
When trouble shooting a dead EFI, one examines two areas:waynegarbo wrote:So.......................
Check all three timing-belt sprockets (cam, distributor's, and crank) for correct alignment..or use a timing light.waynegarbo wrote:How do you check for correct spark?
The computer does the adjustment, so if IAC is working, that's all.waynegarbo wrote:IAC
Test Procedurewaynegarbo wrote: IAC valve
