Heater Core Firewall Junction/Coupler bypass - DIY write-up
This topic is in the MVS Volvo Repair Database » Heater Core Hoses Fix
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Hey everyone, do we have any figures or statistics on how well the heater core firewall junction/coupler bypass has turned out for folks? It seems to make so much sense to me... Just wondering.
Retired:
2015 Volvo S60, T5, 85K
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Ya, it works 100% of the time. You're just removing the brittle plastic coupler and replacing it with heater hose.
theWIFES_S70
Sounds good to me! Thanks polskamafia mjl!
Retired:
bugs11
Year and Model: 850 1996
Post by bugs11 »
Worked for me, did this mod last winter. FWIW I replaced the last "old" section of hose in the coolant system on my 850, the upper reservoir return, with Volvo OEM this past weekend. Pricey little piece of pre-formed hose, but it needed to be replaced.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
theWIFES_S70 wrote:Hey everyone, do we have any figures or statistics on how well the heater core firewall junction/coupler bypass has turned out for folks? It seems to make so much sense to me... Just wondering.
Probably 10k on my bypass, and it's working great.
Everything else on the car has fallen apart.
Been thanked: 504 times
Post by cn90 »
Look at my post DIY right before your post above.
It works perfectly and the cost was peanuts.
theWIFES_S70
Oh man, I forgot to order the Volvo OEM o-rings! (3545586) Thanks for that heads up!
Retired:
bugs11
Post by bugs11 »
I should of mentioned I sourced the heater hose locally. Long story short, I bypassed the heater core when I replaced my head gasket last fall because the firewall junction leaked when I plugged in the new heater core hoses. I took the old heater core fitting to local auto parts stores until I found a decent heater hose that fit snuggley. I think I paid about $5 for three feet of hose. I also didn't drain my coolant when I did the hack. I took a couple of wine bottle corks and whittled them into plugs that fit the heater core hose. Then I removed one end of the bypass hose, plugged the bypass hose, held my thumb over the fitting from the engine and then quickley shoved the fitting into the new hose sticking out though the fire wall. I lost a little coolant, maybe 4-6 oz., but it was a lot easier than draining the system.
theWIFES_S70
j-dawg wrote: Everything else on the car has fallen apart.
Man, what a life we've chosen for ourselves, huh? :wink:
Retired:
theWIFES_S70
bugs11 wrote:I should of mentioned I sourced the heater hose locally. Long story short, I bypassed the heater core when I replaced my head gasket last fall because the firewall junction leaked when I plugged in the new heater core hoses. I took the old heater core fitting to local auto parts stores until I found a decent heater hose that fit snuggley. I think I paid about $5 for three feet of hose. I also didn't drain my coolant when I did the hack. I took a couple of wine bottle corks and whittled them into plugs that fit the heater core hose. Then I removed one end of the bypass hose, plugged the bypass hose, held my thumb over the fitting from the engine and then quickley shoved the fitting into the new hose sticking out though the fire wall. I lost a little coolant, maybe 4-6 oz., but it was a lot easier than draining the system.
Thanks bugs11, I ordered a roll of 6 feet of Gates hose from Amazon. I think it was 9 bucks. It certainly looks and feels like strong hose. Of course I'll throw up my pictures after I get it done. I have so many corks lying around... I would do this, except I am going to replace ALL my hoses, they're all bulbous! (Like I mentioned in another post, I really do not want to drain this system again...) I am going to keep that wine cork trick in mind though. I like it!
Retired:
