98 v70r lambda light constantly on
Bren
Year and Model: 1998 V70R
Post by Bren »
My lambda light would periodically come on before and now its pretty much on solid all the time.
any idea what would cause this? is this an O2 sensor thing?
my code reader won't show me what codes its throwing
Garage:
1998 V70R
2006 XC90 2.5T - Family Hauler
1993 Audi S4 (Sold)
2001 VW Jetta 1.8T (Sold)
1988 Mazda 323 GTX (Sold in pieces)
Been thanked: 4065 times
You need to get them read. What brand reader are you using?
Putting on O2 sensors without knowing codes is about 90% probability of wasted money and time
bugs11
Year and Model: 850 1996
Post by bugs11 »
Have an auto store read the code and have them clear it if they can.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
That light can come on for dozens if not hundreds of reasons. No reason to suspect O2 sensors until you've had the codes read. If your scanner isn't working have them read at a shop or chain auto parts store. You'll want to write down the PXXX numbered code(s) and post them here.
Bren
Post by Bren »
OK will do - I think I just assumed lambda had to do with O2 stuff - but doing some searching and just figured out its basically a CEL.
Thanks guys - I'll try and pull the codes and post them up!
-b
Garage:
1998 V70R
1993 Audi S4 (Sold)
huzzsaba
Year and Model: 2004 volvo xc90 2.5t
Post by huzzsaba »
Agreed. don't replace anything unless you get the codes read. My guess if the car is running fine is probably the j Hose for the evap system since that is probably one of the most common codes that come up.
2004 Volvo xc90 2.5t
1998 Volvo s70 T5M
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
It can be a transmission code as well as engine.
For this model a Vol-FCR cable and software running on laptop setup will work.
polskamafia mjl
huzzsaba wrote:My guess if the car is running fine...
The "problem" with these cars is that they will run fine even when something is wrong. That's why getting to Stage 0 is so important before you start tuning because even serious problems often times don't manifest themselves in a noticeable way. If I remember correctly forum member Ozark Lee ran an 850 for a while with a disconnected coil to distributor wire without realizing it for some time.
Bren wrote:...but doing some searching and just figured out its basically a CEL.
Exactly. :)
