PCV System Kit Vs. Cleaning Ports?
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Re: PCV System Kit Vs. Cleaning Ports?
Post by Matty Moo »
If you need an abs module and funds are tight, get ahold of me. I have some that have superficial case damage from people trying to open them, otherwise they are functionally perfect. I let them go very cheap just to be rid of them.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
bashosings wrote:Hi there,
Just bought a 1998 v70 base and I'm having the pcv kit replaced as there is smoke coming out of the dipstick. Just confirming what is said below?
"DO PULL your dipstick up so that the pressure is relieved until you get this fixed."
Do I pull the dipstick up or just leave it off till this is fixed? I have to drive the car around town for the next couple of days before I can get it fixed.
Thanks!
leaving it loose is a good idea but pay attention to it. I have seen some so clogged up that it starts to spew oil out of the dipstick tube and running out of oil is worse than blowing the seals. We had one member that rigged up a hose tied to the dipstick tube with a 1 gallon jug "recovery tank" to make it home from buying the car halfway across the country. I think he got to the point where he just started to recycle the oil from the recovery tank about half way through his trek.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Just pull it up to relieve the pressure but keep major stuff from going down the dip stick
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Thanks!
I would just pull it out a little bit, and don't drive it hard. I'm sure you don't want oil thrown everywhere!
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
I´d just pull it up and leave it in so you have no pressure but still nothing getting in or out there.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Has thanked: 1504 times
Been thanked: 3817 times
Thanks!
The best way is to buy a tight fitting piece of hose, pull the dipstick out, push the hose on, and route the hose down to the ground so oil vapors don't crud up your engine, just the environment. If you make this a permanent fix Thor will pop all your cam seals, your rear main seal, and pop a P0455 code the day before your inpsection in environmental retribution.
Has thanked: 292 times
Been thanked: 765 times
I agree, the long hose is the best solution for a couple of days. The long hose routine can still end up with a lot of lost oil, not just lost oil vapor, but you are only talking a couple of days should be OK.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
It's funny how people drive with the system clogged or damaged for years and as soon as they learn about the issue, driving it 3 more days is detrimental.
101
Year and Model: 98 V70GLT, 98 S70T5M
Post by 101 »
^^^ true - but it only takes one trip to blow out one of those lovely seals.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
Everyones fear factor is different. Some won't drive a newly purchased P80 until the change the unknown timing belt components. Others will drive them 50% past service interval.
Eeekks.
