Clicking when Revving Engine
warmblood58
- Year and Model: 1989 245
- Has thanked: 5 times
- Been thanked: 2 times
I noticed the other day while revving engine slightly that engine rocks back and there is a clicking sound. Research tells me that this is most likely lower passenger side engine mount. If confirmed, best aftermarket mount and is this mount easy to change? Thanks!
- Has thanked: 311 times
- Been thanked: 817 times
Is the torque mount bushing on top intact? By far the most common, broken mount.
If you are wondering about the front engine mount (lower passenger side), get a look directly at it. The car will need to be up in the air, then pull the passenger wheel. Is the mount intact, or is the engine sitting on the subframe? Hutchison makes the hydraulic mounts (and quality ones!), not sure if they also make that one. For a 95, I like Lemforder on the front mount.
warmblood58
Thanks all!
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- 10 Replies
- 1788 Views
Last post by elmhome
- 768 Views
Last post by JohnnyD
- 40 Replies
- 5572 Views
Last post by kaneelschep
- 731 Views
Last post by linzrs711
- 895 Views
Last post by difflock54
