What oil viscosIty for 04 v70R?
goldmandan
Year and Model: 1999 S 70, 2000 V70
Post by goldmandan »
Wondering what oil viscosity I should use for the V 70 R is 5w30 good enough or should it be 0w40 or zero 30 synthetic of course
goldmandan
Ok I got 5-30 Mobil 1 synthetic. Is the oil filter same as the regular 2.5s??
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
For Florida, 5W30 is a valuable choice, 10W30 or 10W40 would be even better. I don't see too often a 0W40, Castrol does a good 0W30 made in Germany (do they sell it in the US?). The closer the range between the first number and the second one, the better. A 0Wxx is mainly for very cold climates start up. Mobil 1, Castrol Edge, Pennzoil Platinum come to mind. Mann oil filter is great, I think it's the same for 2.5 but better x2 check
nsjames
Year and Model: 04 XC70
Post by nsjames »
mobil makes a 0-40 synthetic that meets all the specs and has a very low volatility, so very PCV friendly.
it's also fairly cheap
https://www.amazon.com/Mobil-120760-Synt ... 78Z05RYQBA]
and easy to come by.
goldmandan
Ok got Fram filter for the R, got 5/30 Mobil one Synthetic. Should be fine.
Thanks guys!
goldmandan
yes they do sell 0-40 I bought that for my Jaguar.
nsjames
Post by nsjames »
fram is terrible.
oragex
Post by oragex »
If the car has never seen synthetic oil, the synthetic oil will quickly clog the oil filter with dislodged debris. Better leave the Fram filter for no more than 300 miles, then replace it with a better filter. Mann sells off Ebay for around $6.
