how to match front and rear brake tightness?
qwertyjjj
Year and Model: V70 2004
Post by qwertyjjj »
If you replace front pads only, how does a garage make sure that the front brakes match in tightness with the rear 50% worn pads?
Furthermore, if front wears faster, doesn't it mean that when they wear, they will be looser and touch the disc/rotor later than the rear?
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Unlike the old drum and shoe type of brakes, today's disk brake pads ride very, very close to the rotor. Once the new pads are installed and the pedal is depressed a couple times, all of the pads will seat against the rotors. So when you're driving and hit the brakes, all of them will apply friction against the rotor at the same time.
nsjames
Year and Model: 04 XC70
Post by nsjames »
the piston does not retract.
the calipers slide on the brackets.
as the pads wear the piston remains extended and the caliper slides so the outer pad moves as well.
There's no adjustments to be made in a disc brake system, unless there are integrated parking brake things, which we don't have.
qwertyjjj
Post by qwertyjjj »
chrism wrote:Unlike the old drum and shoe type of brakes, today's disk brake pads ride very, very close to the rotor. Once the new pads are installed and the pedal is depressed a couple times, all of the pads will seat against the rotors. So when you're driving and hit the brakes, all of them will apply friction against the rotor at the same time.
They self adjust to distance away from the disc?
nsjames
Post by nsjames »
there's nothing in the caliper that retracts the piston.
the pads always ride on the discs.
Been thanked: 4065 times
Correct.
Drum brakes use springs to pull the shoes away from the drum, so that the clearance between shoe and drum has. To be adjusted periodically. Disc brakes self adjust.
