ETM software
churd9
Year and Model: 1999 v70
Post by churd9 »
i need a etm software transfer i bought a xemodex etm used and will start but idles above 1500 help what do i need to transfer the softwale from one th the other? thanks chuck 404-427-0189
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
churd9 wrote:i need a etm software transfer i bought a xemodex etm used and will start but idles above 1500 help what do i need to transfer the softwale from one th the other? thanks chuck 404-427-0189
You need a Vida Dice setup (you just need to install the Dice driver to Windows; nothing else) & contact Doublebug by PM. He has contributed to this thread so go back to find his post, then click on his avatar to post a PM.
krygods
Year and Model: 1999 V70
Post by krygods »
Anyone know if Doublebug still offers help with transferring ETM software?
Has thanked: 1611 times
Been thanked: 4075 times
Yes.
voivodata
Year and Model: v70 2001 2.4 gas
Post by voivodata »
Hello guys , i've drove my car 1,5 years with sacer sensor , but recently p1026 appeared , I've tested with new sacer sensor but it's not the problem . Other then the annoyng service message there is no problem with idle , the car runs very well. Ive also bought other old etm , with same number 8644345 but it goes into "limp mode". Can you give me advice what should I do.
As per my post above.
You'll need a working Dice unit connected to a Windows laptop and an internet connection.
The only other choice is dealer.
voivodata
Post by voivodata »
Thank's guys , i've ordered dice clone :)
pteixeira
Post by pteixeira »
Hi all
Same problem here. Installed new Sacer sensor but problem persist. ETM with yellow sticker. No rought idle, cruise control still working, gas with brake doesn't work and enter limp mode yesterday.
Tried to contact with Doublebug to search some help, but it's not possible to contact him by avatar.
Anyone has Doublebug email or something ?
regards
Tim
Year and Model: 2000 v70
Post by Tim »
Hello I am new to this site so I hope I am in the correct section. I picked up what I thought was a great 2000 v70 that
The previous owner told me the car was loosing power and his dealer said it needed a cat. He did not want to put money in it so I took it. Car was in limp mode. I have just changed the TPS. To a sacer. After reinstalation the car ran and idled perfect for a have hour. I shut the car off parked in garage.
Next day I went to drive it and it had returned to limp mode. I have rechecked volages and grounds and even added the jumper wire to the green wire on the efficiency side to make sure power was good.
I am hoping some one can give me guidance on next steps. Also wondering if anyone else had same situation.
Thank you for reading.
If Volvo dealer said cat is faulty then 99% that's the problem.
Have you read the car with Vida/Dice? Without this you'll be throwing a lot of money and time at parts.
