Fog Lights Inoperative for '95 850 T5-r
warmblood58
- Year and Model: 1989 245
- Has thanked: 5 times
- Been thanked: 2 times
Hello all, fog lights have been inoperative since I purchased this car and need to get them working. Looks like they have been replaced by some aftermarket lights but I saw on a previous post that there is a J relay under instrument panel somewhere? is this true for the 850's? Fuse is good so I need to start tracing various fault locations. Any ideas? Thanks!
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
From http://www.vpcuk.org/forums/showthread. ... or-the-850 :
"The relay and jumper plug are in the relay box up under the drivers side foot well inside the car, the cover is held in with 3 torx head screws. Remove the cover and look up to the right corner. Behind a mass of wiring you will see a relay board. You can tell it’s the relay board as it is white and will have relays in it : )
The relay you have bought fits into the top left hand socket in position 201. Mine was hidden from view by the large purple double relay which operates the interior lights and probably some other things. Take this out fit your relay. The top left hand socket is where it goes. (It will only fit one way). "
warmblood58
Thanks, I think I found the source of the problem. While poking around under the dash, I found the positive and negative leads disconnected for some reason so . . . . let's see what happens when I complete the connections. Not so sure why they were disconnected . . . .
