1996 850R Battery Dying Quickly
wackenhut
Year and Model: 850R 1996
Post by wackenhut »
I have a brand new sears diehard battery installed in my 850R and I notice that if the car sits for about a week or so it loses charge real fast. One thing i may note, the head light switch is kind of interesting in that if the light switch is left in the on position, when the car is turned off the headlights go out and there is no indication that you left the switch on. I am thinking that this may be the culprit. I do try my best to remember that I turned the switch to the off position before leaving the car for the night, but it is easy to forget. Has this been an issue for anyone?
Thank you.
Has thanked: 2199 times
Been thanked: 1851 times
You can leave the light switch in the on position with the ignition on. The side-lights will stay on though if you leave the light switch in the middle position between OFF and ON.
Sounds like something is drawing down the battery. Run a draw down test and pull each fuse in turn to find which circuit has a parasitic draw. Then eliminate each item in the circuit.
2 favorites are the glove box light staying on even with the door closed and in a sedan the trunk light staying on.
Azik09
Year and Model: S70 T5, 1997
Has thanked: 2 times
Been thanked: 31 times
Post by Azik09 »
Is there an original radio installed or not?
If my English is bad, please correct me :oops:
wackenhut
Post by wackenhut »
Yes, there is an original radio.
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
scot850 wrote:2 favorites are the glove box light staying on even with the door closed and in a sedan the trunk light staying on.
This. Certainly the easiest to start with.
Can be very hard to see if the glove box light stays on, and in a week, it'll certainly tap your battery of juice. The bracket thingy in there gets a little wobbly over time, and the door pushes the whole thing in, instead of just the switch.
If your headlights are off, they're off - that's the good thing about lights - you can tell when they're off or on, by there being light or not. ;)
- S
[Sold] '97 S70 T5
wackenhut
Post by wackenhut »
What is the best way to tell if the glove box light stays on or the trunk light?
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Here's a good video on doing a parasitic draw test. (Which hopefully, you will not have to do!)
The easiest way to check the glove box light and the trunk would be to press (or is it depress?) the little levers that are supposed to shut off the lights. They should shut off at the slightest touch. And open up the rear seats and see if the lights are on...
Retired:
2015 Volvo S60, T5, 85K
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
wackenhut wrote:What is the best way to tell if the glove box light stays on or the trunk light?
Start recording video with your phone.
Place phone in glove box.
Close glove box.
Review video.
:mrgreen:
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
wackenhut wrote:...if the light switch is left in the on position, when the car is turned off the headlights go out and there is no indication that you left the switch on.
That's how it is supposed to work. That way if you accidentally leave your headlights on you won't kill the battery. You need to test for parasitic draw as mentioned above.
theWIFES_S70t wrote:Here's a good video on doing a parasitic draw test.
I love Eric The Car Guy! :D
bugs11
Year and Model: 850 1996
Post by bugs11 »
Might be your glove box light. The light in the glove box would remain on when the car was off and drain the battery on my 96 850. I removed the switch assembly for the glove box light. No more dead battery.
