96 850 Turbo - Upper and lower torque mounts R&R
bugs11
Year and Model: 850 1996
Post by bugs11 »
R&R'd the upper and lower torque mounts today with Volvo OEM. MacGyver'd a upper torque bushing press out of materials around the homestead. Worked great, pressing the original one out was a lot harder than pressing the new one in. Can definitely tell difference in transmission shifting smoothness with the new mount installed. The original bushing was about 2/3 torn through, my guess is it would have broke in a week or two, even though I was driving like a proverbial old lady (pained me to get passed by a new Audi the other morning).
Note the difference in OEM and new Volvo OEM (Made in Poland) firewall upper torque mount.
My interpretation of a torque mount bushing press, installing the new bushing. If anyone wants it I'll mail it to them; you'll have to supply the threaded rod. Longest part of the project was designing and building the busing press. The tall piece of plywood was so I has something to hold onto, it really wasn't needed. Note the small black line on the bushing indicating "arrow pointing up is here".
Has thanked: 311 times
Been thanked: 817 times
14 stars on the homemade press, I like it.
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
I agree. Great looking press that we can all fabricate out of pieces of wood we all have lying around.
I actually just ordered these mounts on Friday. Bugs, is it hard at all to get at the nuts holding the firewall mount?
Retired:
2015 Volvo S60, T5, 85K
RigsPGT
Year and Model: Red 99 S70 T5,
Post by RigsPGT »
You'll need to remove the plastic cowl that wraps the windshield to get to the nuts which means you need to also remove the wiper arms. Not bad, just a couple of extra steps.
99 S70 T5, The Red Devil
Ported 19T and R manifold, 3" DP with Magnaflow race cat, 2.5" cat back, Precision FMIC, Rigs intake pipe, H&Rs, Bilsteins, 302's with Akebonos, Jewels, HIDs, egg crate grille, transmission cooler.
theWIFES_S70
Thanks for the directions, Rigs. I had been looking on here for directions on how to do this but didn't/couldn't find any. I thought I had to remove the cowl. (But knowing me, I was probably just going to try to force my way in) there!) :lol: I won't do that now.
Retired:
beigg
Year and Model: 850 97
Post by beigg »
theWIFES_S70 wrote:Thanks for the directions, Rigs. I had been looking on here for directions on how to do this but didn't/couldn't find any. I thought I had to remove the cowl. (But knowing me, I was probably just going to try to force my way in) there!) :lol: I won't do that now.
It not needed 100%.
I left the wipers in place. Removed all the cowl screws and weather stripping, used a closed end crows foot wrench to isolate the nuts from turning.
ugh smh 850 Turbo fridge
bugs11
Post by bugs11 »
As stated you need to remove the cowl, which means you have to remove the wiper arms. The nuts holding my wiper arms were barely tight. There's a wiring harness in some clips that runs above the firewall mount bolts. I popped the harness out of the clips to get access to the mount bolts. The mount bolts were really, really snug. Not sure if it matters, but I put blue Loctite on the threads when installing the new mount.
Replacing the upper and lower torque mounts definitely made everything smoother, shifting and reduced vibration at speed.
