Timing Belt Job Gone Wrong... '99 S70 T5
- Has thanked: 316 times
- Been thanked: 531 times
That's exactly how it sounds! I'm thinking you're right with the car having lawnmower syndrome. We're going to get back to work on it Saturday, so I'll let everyone know what happens. I'll get that tensioner properly aligned and fix the lawnmower syndrome.
- Has thanked: 311 times
- Been thanked: 817 times
It may well be *only* LMS but always good to sort out the timing then proceed.
That's my reasoning. I want to make sure everything is right!erikv11 wrote:It may well be *only* LMS but always good to sort out the timing then proceed.
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Listened to the video- My S70 a few years ago did that with a bad throttle position sensor. If you unplugged it by chance, make sure it's plugged back in - that could be the only thing wrong. Did you read your codes after the TB re-change and no start?
jantt
- Year and Model: C70 2000
- Been thanked: 2 times
I have a 850 GLT 1992 without VVT so don`t know if it is the same.
My marks on camwheels was way off.
Set the crankshaft on mark and lock the cams in the back and see to that cyl. 1 is on top.
That worked for me.
Factory cam marks are not spot on, but mine engine is running perfect.
That worked for me.
I haven't checked for fuel pressure.angelglo wrote:I'm just throwing this out there but do you have pressure at the fuel rail?
Every time I go over there I forget to bring my scanner... so I haven't checked for codes. I don't believe I unplugged anything other than the coolant level sensor.MadeInJapan wrote:Listened to the video- My S70 a few years ago did that with a bad throttle position sensor. If you unplugged it by chance, make sure it's plugged back in - that could be the only thing wrong. Did you read your codes after the TB re-change and no start?
you may as well run different scenarios. fuel, spark, timing. Fuel pressure can be as simple as unscrewing the cap and pressing the shredder valve. If you do not get pressure at all, that is not good. Though a fuel pressure tool would be ideal.
- 5271 Views
Last post by jimmy57
- 23 Replies
- 17187 Views
Last post by jonesg
- 22 Replies
- 3210 Views
Last post by precopster
- 1269 Views
- 1891 Views
Last post by obayha
