Hi,
I have a Volvo XC90 2.4 D5 2004.
But none of the buttons on the steering wheel are working - not volume for radio, not cruise control.
Sympthoms are following:
* buttons on the steering wheel are lighted up
* buttons on the steering wheel are not working, none of them
* horn is not working
I have checked internet over and over and have 3 conclusions, what might be faulty:
1) steeling wheel lining/wire/connections - but in this case they would work periodically and the buttons would not be lighted up;
2) steering wheel module (swm) - in this case also the turn signals would not work and also the headlight would be faulty;
3) clockspring - in this case the airbag light should light up in dashboard.
I have heard that this is common issue for V70, XC70, S60, S80, XC90, so I believe someone had similar problem before.
Please share, what was the solution.
Thanks in advance!
XC90 steering wheel buttons not working
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
perhaps the contacts on the backs of the buttons are dirty or corroded. Has the wheel ever been off for repairs? Is there a separate connector on the SWM for the buttons? perhaps that is not properly connected/contacting, also, has the radio ever been removed? maybe the leads are not connected at the module for the radio.
Current Volvos:
- 793 Views
Last post by Juhizz
- 9 Replies
- 2908 Views
Last post by Nikolaech
- 652 Views
Last post by volvoxc7012345
- 586 Views
Last post by jimmy57
- 1227 Views
Last post by WillieEvans
