Ive bought myself a parts car, manuals are getting very hard to find here so I snapped this up quick smart online without test driving it. The seller said he hadn't driven it for 12 months but it drove fine then.
So today I tested it and couldn't engage any of the gears, clutch feels okay and the external slave is moving the fork. funny thing is let the car roll abit and it goes into gear or turn the motor off and it goes into gear but with engine running and at a standstill no gears engage.
On a flat surface in gear and clutch pedal pressed it doesn't roll even at 3-4k rpm
Clutch bad or gearbox faulty??
1998 V70 M56 parts car question
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
Sounds like the clutch disk might be seized to the flywheel. How about this: Make sure the area is clear in front of the car. Then try starting the car in gear, with clutch pedal in. If the car lurches forward, disk is seized. Just the abrupt action of starting in gear might break it loose, but you could also crank it with clutch pedal in and foot on brake, to see if that releases it. Be careful!
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
MilehighV70XC
- Year and Model: '99 V70XC, 143,000mi
Have you changed the fluid and bled the clutch? That would be the first thing to do.
With the car running and clutch pedal fully pressed, try putting it in first gear as you slowly rev the motor up to like 3500rpm, Kind of like if the trans did not have syncros or you where rev matching. What about the other gears?
If you can get it in gear it would seem to me to be the clutch is not fully disengaging.
Small chance, but the syncros might be completely shot.
renns
Milehigh - he says the clutch feels normal, and the fork is moving properly when pedal depressed, so it sounds like the clutch hydraulics are doing their job. We'll need to wait for an updated from daryl.
- darylrobert
the slave cylinder is leaking, the rubber boot had some fluid in it but not much, being a parts car I am not interested in buying new parts for it. When I rev the car to 3500rpm like Milehigh said it shifts into gear, then once moving I can select other gears using the pedal without any grinding but not when stopped. I have started it in gear and bleed the clutch but its still the same.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Sponge time.
