Make a Brake for It with Bosch Brake Kits
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
https://www.fcpeuro.com/products?keywor ... rand=Bosch
Brakes are one of the most critical components on your vehicle and typically, with time and use, will wear out faster than any other components or systems.
Over time you may notice a difference in brake pedal feel, performance, and/or appearance. You may also experience a pulsation in the brake pedal due to warped rotors and/or grinding caused by metal to metal contact of the brake pad backing material which is making contact with the surface of the rotor. This is caused by a lack of compound material. Other conditions you may experience are squeaking, glazing of the rotors, heat spotting, rust, or a noticeable lip on the outside of the rotor signifying wear.
The brake components in our Bosch brake kits will offer an optimal level of braking performance at an affordable price. Bosch is one of the most well known names in the automotive industry with quality you can count on. The brake pads have a semi-metallic compound and are designed to be similar to the stock counterpart. Each brake pad is fitted with a pre-attached rubber core shim traditionally used only by OE manufacturers to produce quieter, more durable pads. A protective coating is used on each brake rotor to prevent rust and corrosion while providing a clean look when fitted behind alloy wheels. The brake rotors are 100% balanced for smooth operation eliminating vibration. The vane configuration provides more efficient heat dissipation while extending the life of the rotor.
View all our Volvo Bosch brake kits here - https://www.fcpeuro.com/products?keywor ... rand=Bosch
As always, if you have any additional questions please feel free to email me personally at [email protected]
