s70 driver electric seat repair
jfms99
Year and Model: 2000 S70 Volvo
Post by jfms99 »
I have a 2000 Volvo S70. Right now the driver side electric seat does not work.
When I push any of the buttons I can hear a clicking sound but nothing moves.
I took the control panel out to see of there was anything to clean but nothing really there.
Put it back in and have the same clicking sound when I push any of the buttons.
So I don't think it is the motors since nothing works at all.
Could it be the control board is bad and needs to be replaced?
Have checked all the fuses and they are good.
Any help or advice appreciated. Thanks.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Welcome to MVS!
The cable inside needs to be repaired.
http://volvoforums.com/forum/volvo-850- ... air-16364/
And Robert's video:
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
I've never gotten a hold of the diagrams for the passenger side power seat,
so I apologize in advance if I'm not right about this. I'm pretty sure that since
there's no memory on that side, there's no control box. Just the switches in
the side panel of the seat bottom. They're a type of snap switch, so even if
there's no power, they'll still make a clicking sound.
If none of the switches work, I'd start with checking for power at their
main connector under the seat. IIRC, it's protected by one of the circuit
breakers in the fuse box near the windshield.
EDIT - Yup. It's the CB in position 40. See the attached PDF.
98 S-V70 Fuse Locations and Legends.pdf
(678.65 KiB) Downloaded 315 times
dosbricks
Been thanked: 4 times
Post by dosbricks »
S/V70 is notorious for seat switch failure, but since none of the switches are working, it could be the module under the seat.
The tread below has to do with the switch pack itself:
https://www.matthewsvolvosite.com/forums ... ch#p394880
The switch packs are the same across several models, even XC90. If you have a pick-n-pull junk yard nearby it might be worth harvesting one to see if it takes care of the problem. You don't have to change out the pack, just unplug the existing one under the seat and plug in the JY one while still in the parking lot. If it doesn't fix it, take it back for a refund.
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Every time we have a seat issue it has been the switch controller on the side of the seat. This covers about 12 cars starting with the 94 850. The excellent advice from dosbricks is exactly the steps I would follow.
jfms99
Post by jfms99 »
Well I went back and checked the fuses, I forgot on that car there is another set of fuses and to get to them you have to take out about 4 screws to pull that top off. It was a bad fuse so everything is now working.
Has thanked: 2199 times
Been thanked: 1852 times
Love it when it is that simple!
BEJinFbk
Post by BEJinFbk »
Step 1 - Check the power supply.
Step 2 - Refer to step 1... ;)
And don't talk about fight club!
