Hi,
I just bought 4 new tires and had them balanced. They put the weights inside the rim (weight strips). When I went to another location to have them rebalanced, they put the weights on the outside of the rim. It definitely does not look as good, but wondering if the shop just did not have the weight strips or if one way is better then another. Personally I would prefer that they do not show. Please let me know.
Thank you.
1996 850R Balancing New Tires
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Its just a cosmetic thing I think.
- Has thanked: 2200 times
I hate to see the weights on the outside or even on the inner edge for that matter. Those knock on weights where I live damage the tire finish and cause the alloys to blister where they attach. Also we have a family member, who has a habit of parking by feel at a kerb, and if it catches a balance weight on the outside of the rim it runs the weight around the edge causing a lot of paint damage to the rim.
The downside to the balance weights being stuck on is they can come adrift. Also had issues where there is not a lot of room between the rim and the brake caliper causing the weights to be pulled off and seriously damaging the inside of the rim.
If there is plenty of room between the caliper and the rim, I prefer to go with the sticky weights.
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
Do most places do sticky weights? I purchased my current tire set from Discount Tire (brother who used to work there gave me a sweet discount), and they do free rotating/balancing on tires purchased from them. Is it just something that can be specified?scot850 wrote:I hate to see the weights on the outside or even on the inner edge for that matter. Those knock on weights where I live damage the tire finish and cause the alloys to blister where they attach. Also we have a family member, who has a habit of parking by feel at a kerb, and if it catches a balance weight on the outside of the rim it runs the weight around the edge causing a lot of paint damage to the rim.
I agree, the outer weights look horrendous.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
Not all places offer it as I think they are more expensive so you have to ask. They also have to make sure they clean the area where the weights are to fit very well to make sure they don't come back off. If you want sticky weights, then ask first and if they don't offer it, go somewhere that does!
Good luck!
Good luck!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I hate steel wheel weights on alloy wheels.
They look awfull and damages clear coat on alloy wheel.
I always insist on proper alloy wheel weights...sticky weights.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1070 Views
Last post by Silvertank
- 1477 Views
- 801 Views
Last post by jonesg
- 1470 Views
- 14 Replies
- 2188 Views
