Temp control fan always on.
Fan is always on when car is running , and sometime it comes on when the car is off with no keys in it. Any clue? 2002 Volvo s60 base Thanks Dwayne
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Are you talking about the fan at the front of the car or in your AC system? If the one in your engine bay that's usually a sign that the engine coolant temperature (ECT) sensor has gone bad. Does the temp of the car (as indicated on your dash) fluctuate? If it does, that's another indication of this issue. The fan starting on its own is suppose to happen but not after the engine has cooled completely.
MadeInJapan
Ah, okay... LOL. Yes, very strange that it stays on. You sure you don't have auto engaged with thermostat? Hmmm, but it runs even with the key out right? Then there has to be some cross bleeding between positive power wire somewhere... Sorry, I'm not much help. Hopefully someone who knows these units can chime in to help you.
I understand NOW that it clears the evaporator. NOW the fan(inside the car) doesn't stop blowing ever as long a car is on.this has nothing to do with the fan coming on to clear the evaporator. do I need to replace the resister?
- 1137 Views
Last post by richardgengle
- 1798 Views
Last post by Earn_est_89
