Coil pack screw
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Post by clifford06 »
Greetings . What size are the screws that hold coil packs in place ?
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Not sure of the actual screw but all of mine have been 10mm bolts.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
A 10mm head should correspond to an M6 screw.
benpineapple
Year and Model: '06 V50 T5, '13 XC90
Has thanked: 5 times
Post by benpineapple »
j-dawg is right, 10mm M6 screw, aprox 1.25" long will do.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
Has thanked: 1609 times
Been thanked: 4064 times
Important they are clean and tight as they ground the high voltage part of the coil.
Been thanked: 504 times
Post by cn90 »
Are you sure?
I thought the 10-mm bolt is only for anchoring the coil down.
The grounding process is via the threads in the spark plug itself.
The plug grounds through the thread, correct. The ground side of the coil that. Generates the spark goes through the attach screw..if you flip the coil over you will see the attach point is copper to make good contact with the engine block
