2006 XC90 Parking Assist.
cantgrumble
Year and Model: 2006 v70
Post by cantgrumble »
Warning light shows 'Parking assist service required'....Will I be lucky enough for the problem to be a simple fuse ? Or as per my life story the problem will be more complex. How would you diagnose / solve the problem.
Thanks.
mydamnvolvo
Year and Model: Lots
Post by mydamnvolvo »
cantgrumble wrote: Or as per my life story
I feel your pain. I have two v70 xc's and one stalls and one overheats. First, I am guessing your car was never lifted, correct? Second, I am also guessing that you cannot see any visual damage to the sensors. Also, when you put the car in reverse, does it constantly beep, or does it not work at all?
Current:
00 V70 (Daily)
01 V70 (Trips)
94 300zx (High School Present)
01 V70 (Hub)
08 GranCher (Daught)
01 740iL
09 C40 (Son)
Former:
93 BMW 525i-Daugh's-Seized
02 Chrysler T & C-Kid Hauler-Fire
72 Buick GSX-Dad's-Corroded
76 Golf GTI-Mom's-Died
97 960-1st-Timing
cantgrumble
Hello....thanks for reply....The car has never been lifted, and the 'beeper' does not beep when put in reverse or about to hit a brick wall.
Hope this helps.
mydamnvolvo
cantgrumble wrote:Hello....thanks for reply....The car has never been lifted, and the 'beeper' does not beep when put in reverse or about to hit a brick wall.
Hope this helps.
So it is probably not too damaged, if at all. It might just need to be reset/recallibrated
Current:
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
cantgrumble
Thanks for that,
Well it is not the fuse,I have ruled that out.
When you say reset/recallibrated dies this involve a garage with diagnodtic equipment and how expensive is the job likely to be.
Thanks.
Colinbos
Year and Model: 2008
Post by Colinbos »
There are 4 rear park sensors on the rear, yes ?
They may need ALL replacing (you can use Land Rover parts or Ford,as they are the same) or your ECU, situated behind the rear left interior 'turns' surround. Its a black box. Sometimes the wring loom goes faulty too. Id start with replacing the sensors as they are the cheapest.
Do you have access to VIDA to check the fault codes ?
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
I agree with Colinbos - if you can, read out the fault codes and see what the car thinks the problem is before just randomly replacing parts.
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
