Hey everyone,
Just wanted to get some feedback. I installed an FAE Coolant Fan Temperature Switch (https://www.fcpeuro.com/products/volvo- ... -9186486-1). Earlier in the Spring when I got the P0116 and P0117s and the car wouldn't start... I know, I know, always go OEM... Well, at the time, I was having a crisis of faith and was hoping I could get some goodness out of the FAE one...
Today, I noticed a really long crank to start the car. Could this be related to this sensor? Even on a cold car? I read the post on here a week ago about a warm engine start problem. (In which case, the non-OEM ECT would make sense...) Before the Fuel Pump and relay both went out, the car used to crank on immediately. (I really miss that feeling...) Ever since the Hella pump rebuild it's taken a little longer, but today, wow...
What are the common causes of a long crank? Thanks again for your input everyone!
98 S70, N/A Long crank... engine Temperature Switch related?
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Retired:
2015 Volvo S60, T5, 85K
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
What's the definition of a cold start in Queens this time of year?
Disconnect the ECT cable and see if it'll start. If so then it's Tango Uniform. If the sensor resistance is too low when cold, the ECU will think the engine is warm/hot and not dump in extra fuel (by increasing the duty cycle to the injectors). Pulling the harness, causes the resistance to go to infinity, telling the ECU the engine is VERY cold and to "pour-on-the-gas".
To my knowledge, the 98's only have one engine temp sensor and EVERYTHING engine/coolant/cold/hot is based on it.
M1 10W-30 HM
M1 10W-30 HM
- theWIFES_S70
Well, a cold start as in, starting the car for the first time in two days!sleddriver wrote:What's the definition of a cold start in Queens this time of year?
Retired:
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
For sure - a bad ECT left me with all kinds of starting issues.
'98 S70 T5
2016 Chevy Cruze Premier
- sleddriver
I meant how cold is it in the mornings in Queens?
M1 10W-30 HM
M1 10W-30 HM
- theWIFES_S70
I filmed a video of the crank... (This morning it was 55 degrees.) What do you guys think? I feel like it's fuel related (the engine, once at operating temperature, purrs like a kitten and starts like, well, like the groaning buffalo that our cars like to mimic)... I should just pony up the money for an OEM sensor, huh?
Retired:
jblackburn
Flip the key on (to II) and make sure you have fuel pressure at the end of the fuel rail before replacing the temp sensor. A bad fuel pump check valve can do things like that as well.
That start doesn't seem too bad - mine took 45 seconds to a minute to get going when the sensor went bad - on a 70* day!
'98 S70 T5
- theWIFES_S70
Hey jblackburn, this thing?jblackburn wrote:Flip the key on (to II) and make sure you have fuel pressure at the end of the fuel rail before replacing the temp sensor. A bad check valve can do things like that as well.
We only need this if we have taken the air pump out, right? I miss the instantaneous start we used to have before the fuel pump/relay hiccup. Maybe we should be putting the fuel pump in the "always use OEM" section, too, huh? I will keep an eye on it but won't worry about it too much. I really appreciate your feedback!
Retired:
jblackburn
Yes, splicing a check valve into a fuel line could work.
But in the meantime, just flip the key to II, don't crank, and look near the throttle body end of the fuel rail - there's a little blue cap and a port you can depress with a rag in hand to see if there is strong fuel pressure there or just a dribble.
'98 S70 T5
- 915 Views
Last post by Kokonradus
- 798 Views
- 4711 Views
Last post by EChem
- 29 Replies
- 7142 Views
Last post by Chuck W
- 2119 Views
Last post by benpineapple
