1996 volvo 850 brake noise
How Oxygen Sensors Work
My 1996 volvo 850 has been making brake noises for a long time. After going to midas, I changed a new pair of front brake pads and discs according to their suggestion. Also, I had my calipers checked, which were said to be totally fine, although they seem very rusted. Now, the car is still making noise while braking. What could the problems be? Thx!
- Year and Model: Many Volvos
- Been thanked: 76 times
Can you describe the noise? Is it a squeal, a grinding sound, or a rattle?
- Tsquared
- Year and Model: 11 C30
If you paid the big bucks for a shop to fix your brakes take it back and make them fix it correctly or give you a refund.
T
T
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
Volvos are notorious for squealing brakes unless they are replaced with OEM Volvo brake pads. I just replaced my front rotors and pads a couple of weeks ago and I am having good luck with Mintex brand pads, at least on the front, but I used some RTV like goop from Permatex called "Disc Brake Quiet" that I got at the local Advance Auto Parts. FCP Groton suggests a brake grease called Syl-Glyde as a backer on the pads to keep them quiet.
From past experience with my 740's the Raybestos or other national chain pads will scream like a banshee and there isn't much you can do about it short of changing out the pads again. The "Disc Brake Quiet" or Syl-Glyde is worth a shot though.
For what it's worth, the fronts tend to be more manageable than the rears when it comes to squealing.
Just to make sure we are communicating well here, it goes on the back of the pad, not on the friction surface.I will try to lube the brake pads soon..
I have visions of the first time trying to stop if someone got it wrong.
- akitawagon
- Year and Model: 1997 855R
For the rear pads, make sure you also use the shims.turbotim2 wrote:And even the OEM pads in the rear will squeal too. Use ALOT of the brake pad lube and that will help.
I only use OEM pads now since some of the aftermarket ones I've tried never stop squealing.
1998 V70 T5 223K
1997 855R 215K
1997 855R 124K KIA... distracted driver on phone
1997 855 T5 141K KIA... water pump
1996 850 GLT 160K
1995 855 GTA 325K KIA... distracted driver on phone
1993 850 GLTS 201K KIA... t-boned
1997 855R 215K
1996 850 GLT 160K
- 2386 Views
Last post by MoVolvos
- 1256 Views
Last post by Ozark Lee
- 573 Views
Last post by GrumpyOldMan
- 11 Replies
- 2517 Views
Last post by dyn blin
- 178 Views
Last post by jotoya
