It's fine, I use it all the time and it's compatible with the spec ATF for this trans.scot850 wrote:Check the oil you are planning to use for the trans. I believe that is wrong for a 98.
Look what I did to my 1998 V70XC
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- instarx
- Year and Model: XC70 T6 2011
The transmission takes more than 4 quarts, and Type 3309 is not compatible with Dexron - so don't mix the two. Mobil tech support says they are not compatible.shiloh51933 wrote:Actually I didn't pay for the o2 sensor this time, I exchanged the defective NTK o2 I purchased last June. They ordered the wrong size NTK o2 sensor, so instead they gave me the Bosch o2 that they had in stock and it just happens to be original equipment.Clemens wrote:Oxygen sensor. Interesting. One thing i really avoid to replace whenever possible cuz in my heart i am cheap...
The wires and rotor and cap will make it mich smoother. At least they did that to my R
I have 4 quarts of Aisin Warner ATF(3309) that's going in for a drain and fill.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
- shiloh51933
- ko
Its a drain and fill, so 3 to 4 quarts and this ATF is what is used from the factory.instarx wrote:The transmission takes more than 4 quarts, and Type 3309 is not compatible with Dexron - so don't mix the two. Mobil tech support says they are not compatible.shiloh51933 wrote:Actually I didn't pay for the o2 sensor this time, I exchanged the defective NTK o2 I purchased last June. They ordered the wrong size NTK o2 sensor, so instead they gave me the Bosch o2 that they had in stock and it just happens to be original equipment.Clemens wrote:Oxygen sensor. Interesting. One thing i really avoid to replace whenever possible cuz in my heart i am cheap...
- shiloh51933
I must make a correction on this thread, I confuse our Cross Country's sometimes. My wife's'04 is a 5speed a/t that's uses 3309, I used Aisin Warner ATF but it does not say 3309 on the bottle. It's the OEM manufacturer of a lot of the a/t in Volvo vehicles and OEM ATF used in some Volvo's.
- shiloh51933
No Regardless JWS3309 is backwards compatible with Dexron III.
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Apparently you can't mix them though!!! Beware!!shiloh51933 wrote:No Regardless JWS3309 is backwards compatible with Dexron III.
JRL
- Year and Model: Several
- Been thanked: 16 times
If you flush it but I would not mix themshiloh51933 wrote:No Regardless JWS3309 is backwards compatible with Dexron III.
- shiloh51933
Dexron III is a synthetic blend right, 3309 is full synthetic right. If this is true then adding some full synthetic to a synthetic blend shouldn't harm anything but I could see why you might want to keep them separate.JRL wrote:If you flush it but I would not mix themshiloh51933 wrote:No Regardless JWS3309 is backwards compatible with Dexron III.
JRL
3309 is a mineral oil no synthetic whatsoever
- 506 Views
Last post by m96ag
- 1004 Views
Last post by raivis_rsn
- 1176 Views
Last post by Ben850
- 25 Replies
- 4581 Views
Last post by erikv11
- 76 Replies
- 15021 Views
Last post by callahanoffroad
