steering feel
Clemens
Has thanked: 473 times
Been thanked: 219 times
steering feel
Post by Clemens »
So i was wondering why the steering on my 96 R with 205/45 r17 feels so much less power steering supported than my 95 10V wit 195/55 R16? Are they supposed to feel that different? I doint the 1cm of width makes that mich difference. Or is there an adapting unit that reduces force at higher speed as some newer cars have it that is going bad on the r? No leaks, no strange noises, everything seems fine except for the difference in steering support.
Any ideas are welcome
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Has thanked: 1846 times
Been thanked: 1710 times
If you can swap the front wheel over from both cars, I think you will find they are most likely the same. The issue is not that the tires are 'Only' 1cm wider, that are also got more surface in contact with the ground. Do you run similar pressures in the tires?
My 2000 R on 225/45/17 is easier to turn than our older 98 V70 Xc was on 195/65/15's. They do have different pumps though!
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
From my experience no two Volvo P80s have the same feel in the steering be they the same year and same model or not. They all seem to have their own unique personality. The AWD versions are always very different but even two 850 FWD sedans, side by side with the same tires, will feel different.
Clemens
Post by Clemens »
thank you, gentlemen.
Summer: 1996 855 R
Donor: 1995 854 10V
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The are quite a few things that can interfere with the steering assistance, going from old fluid, rusty rack, worn pump, seized lower steering shaft coupler, rusty steering shaft boot bearing, worn strut bearings, just to name the basic ones
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 28 times
Post by cuhfs »
WD-40 or similar lube on the steering knuckle may help
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
cuhfs
Post by cuhfs »
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
