Screwdriver viscosity test: Mobil 3309 is not OE ATF
zanzabar
Year and Model: '07 V70, '84 245
Been thanked: 4 times
Post by zanzabar »
Seriously, has anyone had good experiences with low viscosity ATF?
Apparently Maxlife is one of these: @40C= 28.8 cSt; @100C = 5.9 cSt. Maxlife seem to work ok?
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
zanzabar wrote:The difference from what I gather from the googles is between kinematic viscosity (screwdriver test) and absolute viscosity (real measurement).
http://www.machinerylubrication.com/Rea ... -viscosity
"The efflux time can also be converted to kinematic viscosities (centistokes, cSt) through the conversion equations"
https://en.wikipedia.org/wiki/Viscosity
packetfire
Year and Model: 2010 v50 2.4i
Has thanked: 17 times
Been thanked: 30 times
Post by packetfire »
zanzabar wrote:
C'mon guys. What is this, the Donald Trump school of tribology?
Not that I am an expert in this stuff, but dripping off of a screwdriver obviously has little to do with viscosity measurements that describe a fluid's behavior inside an engine or transmission.
Yeah, try and lend a hand, and get shouted down.
A discussion of density would have to first focus on the density of the critics before one could discuss density of the fluids. :lol:
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
vtl
Post by vtl »
zanzabar wrote:Seriously, has anyone had good experiences with low viscosity ATF?
Worked really well being mixed with Mobil (drain Mobil & fill Valvoline). After third drain&fill gearbox started to shift worse, and it got better with another d&f, now back with Mobil. So, whatever Volvo puts into our transmission, it has viscosity in between Valvoline MaxLife and Mobil 3309.
So far, with one Aisin 0T4 d&f my 11 years old car shifts better than 2016 XC60 T5 we bought few weeks ago for my wife to replace her 2002 V70, which shifts the best among our 3 Volvos :( V70 has a refurbished valve body and is filled with Idemitsu Type-TLS, which has a bit lower viscosity than Mobil 3309.
Has thanked: 1609 times
Been thanked: 4064 times
I'm sure transmission operation is a function of kinematic viscosity at operating temperature which is a long way from the trademarked screwdriver test. Actual in use experience is the best guide.
vtl
Post by vtl »
abscate wrote:I'm sure transmission operation is a function of kinematic viscosity at operating temperature which is a long way from the trademarked screwdriver test. Actual in use experience is the best guide.
Did you see any examples for two fluids, A and B, when cSt@40 A < B, but cSt@100 A > B?
basically that condition is the operating principle of early viscous couplers, but I think if fluids A and B are same purposed then I would think they trend together.
zanzabar
Post by zanzabar »
What sort of qualities or shifting behavior do you describe as "shifts better"? I'm guessing you mean engages more quickly without any jolts, and no rpm flares or slipping...something like that? I will be doing the same experiment as you have done by mixing the Eneos ATF with Mobil in a drain and fill. I find that my trans (with 100% 3309 fluid) shifts fairly well in the higher gears but low gears seems to slip a bit in first when starting out and 1>2 shift is kinda slow.
VW TDI refugee
1994 855 (sold)
vtl
Post by vtl »
zanzabar wrote:What sort of qualities or shifting behavior do you describe as "shifts better"? I'm guessing you mean engages more quickly without any jolts, and no rpm flares or slipping...something like that?
"Better shifting" is how you shift your car with the stick when you own it for longer than two weeks: no one else in the car notices when you change the gear.
