I'm having my serpentine belt and tensioner replaced but also need to ask about this pulley --
https://www.fcpeuro.com/products/volvo- ... 70-9146139
I have 140K on car -- wouldn't it be a good idea to replace this also? Is it a problem to replace or easy if they're replacing the tensioner at the same time?
I also saw "tensioner pulley" ? -- is that already part of a new tensioner?
Thanks very much -- and I mean that.
Serpentine belt -- pulley?
- Has thanked: 2199 times
It would help us if you can specify what model of Volvo you have. Is it a V/C/S 70 from 1998 and is ait a GLT, Base, T5, R model?
If you are having the full tensioner on serpentine belt replaced, there may be an idler pulley there also. This part should be part of the full tensioner assembly which has a pulley like this and is attached to a spring loaded arm which is the tensioner.
What/where are you ordering the parts from as this also helps us. Reason being some aftermarket parts are of poor quality.
So you were correct in the first note in that is the idler pulley and not a replacement pulley for the tensioner (my error). So that part is correct.
Tensioner should be correct.
Is your car a standard shift and does it have A/C? The belt listed is for a manual/standard shift without A/C. There is a different part number listed for an auto without A/C (9146844) and for A/C is listed as (9186352) assuming you have a B5234T3 motor.
Teddy1975
- Year and Model: 2007 V50
- Been thanked: 7 times
In my humble opinion, there's no need to replace the pulley mentioned in first post. Only if you can feel any play in the bearing or if it is noisy.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
- Been thanked: 504 times
I replaced mine at 150K or so, it had play.
Most bearings are free-wheeling at 130K+ miles.
I outlined the whole DIY below.
DIY: 1998 Volvo S70 Timing Belt, WP, Cam Seals, SB Overhaul
https://www.matthewsvolvosite.com/forums ... hp?t=53722
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Mine was free wheeling but not running rough. Being lazy and on the cheap side, I removed the bearing seal and repacked with bearing grease. No more free wheeling but of course not going to last 50K miles.
On the idler I personally would replace the idler at 140k miles. I appreciate $50 is $50 more to spend, but way cheaper than having the bearing fail and the belt possibly taking the TB out as well as I have heard of when the belt broke. By all means, spin the bearing and listen/feel for roughness.
My experience was at around 110k miles on an 850 and changed the belt only for the tensioner to fail a week later!
mar601
- Year and Model: 1998
- Has thanked: 34 times
- Been thanked: 5 times
Ok thanks everybody. I replaced the belt myself years ago so it must have been easy -- used a DIY tool to do it. If I remember right it goes on/off without removing anything?
So -- once it's off, is it pretty easy to put this tensioner and pulley on? Maybe just mounting bolts for the tensioner (2 - 3 or ?)
And how does the pulley stay on ? A "C ring" or something ? Do you use some grease before putting the new one on ?
Does it also pay to lubricate anything in that belt path ? -- THANKS
- 2770 Views
Last post by cn90
- 760 Views
- 9 Replies
- 591 Views
Last post by FrickinHek
- 20 Replies
- 17406 Views
Last post by Hurtfeelings
- 1429 Views
Last post by XC70Rider
