Did you know? 🤔
2001 2002 AW55 transmission, history, stop/start software Topic is solved
2001 - 2007 XC-70
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 384 times
Been thanked: 145 times
United States of America
matthew1
Post by matthew1 » Thu May 19, 2016 10:25 am
Since there's been a rash of questions on 2001 Volvos with this transmission (AW55-50SN for FWD cars and AW55-50 for AWD cars), here's a sticky topic we can use to share notes and experiences. A highly concentrated AW55-50 info topic. After this topic grows, I'll unsticky it and roll it into Links to Major Repairs V70 & XC-70 (2001-07), S60 (2001-09) supersticky topic, where it will continue to be open to posts.
Here's a table with all recent Volvos and their transmissions. Check if your Volvo has this transmission using it if you don't know.
Here's a page with links to topics concerning Volvo's terrible "Stop-Neutral Transmission" software feature that helped damage and degrade countless 2001 and 2002 Volvo transmissions.
Here is a thread talking about the upside of these transmissions
viewtopic.php?f=9&t=84857
Please post to this thread if you've got relevant AW55-50 information, either first-hand info, or a link here on MVS or offsite.
Thanks!
These users thanked the author matthew1 for the post (total 3):
testing123KmSGoFish
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
01_Nautic_V70
Year and Model: 2001 V70 T5
Has thanked: 0
Been thanked: 8 times
01_Nautic_V70
Re: 2001 5-speed automatic transmission & problems - start here
Post by 01_Nautic_V70 » Thu May 19, 2016 10:46 am
Thank you. Sorry to be cluttering things up lately.
matthew1
Site Admin
matthew1
Post by matthew1 » Thu May 19, 2016 11:43 am
Oh I wasn't pointing fingers, Nautic :-). This is just good practice to organize info where there is a bunch of interest/posting on one specific thing.
Also -> Amazon link
01_Nautic_V70
Has thanked: 0
01_Nautic_V70
Post by 01_Nautic_V70 » Thu May 19, 2016 12:24 pm
In this vein, I have a transmission pressure gauge set coming in tomorrow. If my self-performed valvebody clean and rebuild doesn't correct my issue, I'll start looking for signs of either clutch pack and band failure or failure of the ATF pump itself. Does anyone have a table of factory spec pressure tap values (on rear cover) for the various taps? I can do a quick check by disconnecting the cooler, but what really is enough pressure and what is not.
I do suspect there's a pump issue as I noted an increased "whine" from the transmission before it gave out. Almost like a failing power steering pump noise. I'm thinking the noise similarity indicates a failing hydraulic pump. A failed hydraulic pump in an automatic would mean basically nothing works.
Has thanked: 200 times
Been thanked: 647 times
Trinidad & Tobago
Post by abscate » Wed Jun 08, 2016 9:15 am
Attempt to put this into perspective. From the table the AW55-50 family was used in a lot of P2 s from 2000 on
Is the issue with 2001 and 2002 the start/stop software wrecks these transmissions, but 2003-on they are basically sound as that software was removed?
smileyboy
Year and Model: 1998 V70 T5M
Has thanked: 0
Been thanked: 0
smileyboy
Post by smileyboy » Tue Jul 26, 2016 5:55 pm
Will a 2003 fit in a 2001 or a 2005 fit in a 2001? Is it plug and play? I mistakenly posted and didn't see this thread.
1992 Volvo 940 Turbo wagon SOLD
1998 V70 T5M
1999 Toyota 100 Series
2006 VW Jetta TDI
01_Nautic_V70
Has thanked: 0
01_Nautic_V70
Post by 01_Nautic_V70 » Thu Jul 28, 2016 2:01 pm
Smileyboy, no. A 2001-2002 are interchangeable only among those years. Then 2003-2004, then 2005-after. So, there are three different "phases" of AW55's in these cars.
shiloh51933
Has thanked: 9 times
Been thanked: 7 times
shiloh51933
Post by shiloh51933 » Sun Nov 27, 2016 9:08 am
abscate wrote:Attempt to put this into perspective. From the table the AW55-50 family was used in a lot of P2 s from 2000 on
I have 2004 XC70 and a 2000 V70XC so this question isn't for me specifically but for this forum. Since the start/stop software wrecks the transmission on the 2001-2002, did Volvo ever make any software updates to correct the issues caused by the start/stop software?
If U Wanna Play U Gotta Pay!!
matthew1
Site Admin
matthew1
Post by matthew1 » Sun Nov 27, 2016 9:45 am
Also -> Amazon link
Year and Model: Lots
Has thanked: 4 times
Been thanked: 97 times
Australia
Post by precopster » Thu Dec 08, 2016 3:03 am
The SLS, SLU and SLT solenoids behind the valve body cover were a major headache with the bushing material becoming magnetic and attracting metallic sludge that should have ended up nestling in the low mounted filter. Cleaning and re-clearancing these bushings gives some temporary relief but must be done early in the transmission's life before damage is done. Replacement of the valve body is a better more long term fix.
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
