TOTAL PCV System Removal
loshax
Year and Model: 2001 S60 T5 FWD Stic
Post by loshax »
Hey guys!
Ive just red about PCV system, and realized that it can cause a lot of problems...
Is it possible to get rid of that system? Make it just like 70's car? Possibly it would also help for performance if the components for bang in the cylinders would be just clean air and fuel, and not reused gases?
Feel free to corect me if im blabaring something wrong ;)
430 000km and was counting... :(
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I read about some guy who passed a hose between the top engine hole and the lower block hole. Not sure if that does anything? I wonder if plugging all top engine and block holes would be a bypass. Chances are the car won't pass emission tests any long.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Without a working Positive Crankcase Ventilation, you'll have even more problems.
85 GLH, 367 whp
00 Insight, 72 mpg
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Use synthetic oil and change it often, PCV won't bother you until hoses begin to crack (but by then every hose under hood will be brittle).
nsjames
Year and Model: 04 XC70
Post by nsjames »
sure you can delete it.
Then you'll need a catch can to capture the oil vapors. your car will smell terrible anytime it's running. The lack of vacuum in the crankcase will lead to your oil becoming nasty very quickly as the condensate builds and isn't removed.
and the metered air leak from the PCV system
this is what a draft tube looks like, and before PCV/CCV systems this is what you got to smell in traffic
keep the PCV system, fix it and do regular maintenance and it won't be problematic.
loshax
Post by loshax »
Thank you guys! I guess i can relax now, and just mainain my car as usual. :)
Keep up the good spirit! ;)
