I was moving my car today, and accidentally knocked the flasher switch when I shifted into reverse. When I hit the brakes (hadn't bothered to turn off the flashers yet) and noticed the bulb failure warning light flashing with the hazards. Strange thing is that it was only when my foot was on the brake pedal. It didn't do it in any other gears.
All of my turn signal bulbs are good, so that's not the problem. Any idea what it could be?
Bulb Warning Light Only In Reverse w/ Flashers
- Has thanked: 316 times
- Been thanked: 531 times
- Has thanked: 311 times
- Been thanked: 817 times
This is usually due to dirty or rusting contacts in one of the bulb housings. I'd check the tail/stop light ones first since it seems to be tied to pushing the brake pedal.
Remember that the wiring harness in the wagon strut is a known wiring failure spot for any rear light funk.
At first I was really puzzled by this comment but now i get it, I think you probably just misread the post. OP gets a warning flash when the brake pedal is pushed and the flashers are on - the symptoms here have nothing to do with the reverse lights.Marty27 wrote:That's strange. The bulb failure light is not even tied in with the reverse lights. Sounds like an evil short that would drive me nuts.
I also agree that the wiring in the hinge is worth checking out.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
A lot of wiring goes through the "hinge" back there. There's some inevitable chafing, and it's a known problem that wires are stripped or even chewed through there, causing all sorts of strange electrical behavior. Check and see that all wires in that harness are whole and insulated, without damage like kinks and rubbing, and that none of them have snapped off.
It may seem unrelated at first, but electricity is magic (at least as far as I'm able to wrap my head around it), so there's apparently no telling what it'll do. Or won't do, as the case may be.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
I'll definitely check out the wiring, as well as bulb contacts. From what I can tell, the problem is intermittent. I checked again last night after going to the store, and the car won't do it now.
bmdubya1198 wrote:I'll definitely check out the wiring, as well as bulb contacts. From what I can tell, the problem is intermittent. I checked again last night after going to the store, and the car won't do it now.
Classic rear strut wiring symptom. Wait until you punch your lock button, thereby disabling your starter.
See thread and pix
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
Could be a dirty socket to lower the bulb contact. I replaced a bulb with a non perfect, meaning it works but not the exact match for the light, and my yellow light is always on when the lights are on. I have concluded that the bulb I replaced is a different wattage and the car doesn't like that. If you haven't changed any bulbs, then the problem could be resistance due to rust in the socket.
Just another guess.
I know my problem, just been to much going on to change the bulb, as I forgot which one I replaced.
Just another guess.
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
- 2624 Views
Last post by firstv70volvo
- 4126 Views
Last post by silentcircuit
- 2737 Views
Last post by BEJinFbk
- 13 Replies
- 2232 Views
Last post by misha
- 1725 Views
Last post by E Showell
