2007 V70 needs new engine
nsjames
Year and Model: 04 XC70
Post by nsjames »
did they pull the pan and have a look in there?
because if they didn't pull the pan you shouldn't trust their diagnosis, if they had pulled the pan and found a bunch of metal in there I'm sure they would have saved a sample to show you. I know I would have.
dphoss
Year and Model: 2007 V70
Post by dphoss »
Is it worth trying to drop the oil pan and see if I can get to the bearings for replacement? A bandaid or possible fix?
Right now the car is at the shop and I'll need to make a decision. Maybe sell it for parts. The body and interior are in great shape.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
dphoss wrote:Is it worth trying to drop the oil pan and see if I can get to the bearings for replacement? The body and interior are in great shape.
Used engines are from $550 with 90 days warranty. No reason to change bearings.
http://car-part.com
85 GLH, 367 whp
00 Insight, 72 mpg
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Good link for engines it seems. The trick is to get one with lower miles...If your tranny is good, use it- get an exact replacement (same exact numbers on your engine and the one you're buy)...try to find one that is close by so no expensive shipping... It will still require a lot of work!! I wouldn't buy the cheapest one you find ($550)...maybe $1000 would buy you a better one. If your tranny is questionable- try to find an engine with the tranny already attached. Good luck and let us know how things go!
