Get them while you can!
https://www.fcpeuro.com/products/volvo- ... rs-8602456
p80 302 mm brake bracket
- Has thanked: 316 times
- Been thanked: 531 times
They're back!
tryingbe
- Year and Model: None
- Been thanked: 26 times
rguzz wrote:Doesn't appear to fit 850.
They do. I have a set 302 mm brakes on my 94 850.
https://www.volvoclub.org.uk/850_70_brakes.shtml
https://www.matthewsvolvosite.com/forums ... =1&t=38299
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
You'll just have to have wheels that clear them...I know the Perfo will- not sure about the Columba (both look a lot a like and typically are on turbo cars- the perfo on S70's).rguzz wrote:Doesn't appear to fit 850.
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Yes, thanks I remember, for some reason I was thinking the later model brackets were a bit different, but as I now recall these were never on any 850's, at least ones that made it to these shores. The question for me has always been do I want to start looking for another set of wheels other than the stock ones I currently have. But might be good to pick these brackets up and decide what to do later, they should be easily sold if not used.
It will only fit the 850 if you have 16 inch wheels or larger. If I'm not mistaken Columbas are 15s, which were the biggest wheels you could get. Again, don't hold me to that info, because I'm not entirely sure myself, but I do know that 302mm calipers will NOT work with 15 inch wheels.
- 1066 Views
Last post by benpineapple
- 9 Replies
- 1034 Views
Last post by matthew1
- 10 Replies
- 6267 Views
Last post by volvolugnut
- 12 Replies
- 2764 Views
- 2339 Views
