stuck Transmission Torque Mount bolt
Year and Model: '18 VW Golf 1.8T 5MT
Post by 1337 »
My transmission torque mount (TTM) is cracked and dry rotted, so it's time to replace it. (Also, my engine flops around a bit on the 1-2 shift, so yeah...)
I've been able to loosen 3 of the 4 bolts that hold the TTM in place. But, there is one really stubborn 14mm bolt:
Low clearance around TTM bolt
I've tried:
- Jacking up the car to the maximum height of my jack stands (for all of the following).
- A wrench (10" long). Not enough leverage.
- The wrench plus a 2' length of pipe -- too precarious, the wrench just falls off. And, the pipe doesn't fit on the wrench snugly, so I don't have very many degrees of rotation before I'm up against the car or the floor.
- A socket using a 1/4" ratchet. It feels like I'm going to break the ratchet under this heavy load.
- A 3/8" ratchet doesn't fit under bolt "(2)" in the picture above
- A 3/8" ratchet with a wobble extension -- the wobble ends up being pretty much sideways.
- My 1/2" breaker bar definitely doesn't fit.
The bolt is still firmly in there.
So... what tool should I try next?
Current: 2018 VW Golf 1.8T Manual
Previous: 1998 V70 T5 Manual, Subaru BRZ, Mini, Miata, etc.
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
How about removing that aft-most bolt, then use the closed end of a combination wrench of correct size - put a long socket on the other end of the combination wrench and a breaker bar on that. Whole thing angled as much to the rear as possible, and then break it free. I'm not sure I'm explaining this very well - do you see what I mean?
- S
[Sold] '97 S70 T5
Herb Goltz
Year and Model: 04& 06 XC70, '12 s60
Has thanked: 7 times
Been thanked: 5 times
Post by Herb Goltz »
I'd put the wrench back on it and hit the wrench with a mallet or hammer. Keep your thumb over the head of the bolt to keep the wrench from falling off.
2012 s60 t5
2006 XC70
2004 XC70
Sommerfeldt
Or something like this:
- S
[Sold] '97 S70 T5
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
1/4 Inch isn´t the right tool. Try a 3/8 socket (a short one, not a deep socket) and a good ratchet (I like Snap-On, but Craftsman should do as well).
If you can´t break it open from below (I had that on my motor oil drain plug) go to an indie shop of a jiffy lube or something, put the car up on a lift and have them break it loose for you from underneath (or do it yourself, whatever works).
Also, when I was younger I´d always ask my bro or my neightbour to do something like that for me. They just had more punch in their arms than I did.
Sommerfeldt´s idea is good but might still need to much space from underneath.
1996 855 R,
2010 V70 D5,
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Sommerfeldt wrote "How about removing that aft-most bolt, then use ..."
Unless you are sure what the other bolt is for... i would NOT remove it. Hate to see a transmission band let go... Perhaps others know what that aft bolt is for.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
Has thanked: 2197 times
Been thanked: 1851 times
Haven't had a FWD 850/P80 for a long time. My AWD 2000 'R' that pipe you show as a brake pipe in my car is a power steering line. There is a mount at the front on the bracket that can be undone and allowed me to push it closer to the transmission to give more room. I also have an extendable 3/8" ratchet wrench and I needed that with a 2" wobble drive and short 3/8" x 14mm socket to get access.
Have you tried to shock it loose? If you can get some access this a punch onto the head of the bolt, give it a few sharp cracks with a large hammer and then try again.
MadeInJapan
Been thanked: 35 times
Post by MadeInJapan »
No one's mentioned lubricant. PB Plaster- let it sit for a bit...then, I like the idea of a good smack with a hammer! That has never failed for me.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Use a 6 point wrench then use a hammer on it. Do NOT use open end wrench.
85 GLH, 367 whp
00 Insight, 72 mpg
Sommerfeldt
cuhfs wrote:Sommerfeldt wrote "How about removing that aft-most bolt, then use ..."
The rear bolt on the torque mount. There are 3 in a row there, as you can see in the picture. The stubborn one is the one in the middle, while the one next to it (which I'm talking about) will create some difficulty in using the closed end of a combination wrench.
- S
[Sold] '97 S70 T5
